Home > Td5 > Under bumper TD5 LED light bar! Possible?
MC84
United Kingdom 2001 Defender 90 Td5 HT Chawton White
I'm sure I've seen magazine articles which had a light bar slung under the front bumper. Does anyone have links to any vehicles that have had these fitted please?
I don't really want to fit a light bar on the roof as I'd prefer to keep the profile I have. Mike
Hard Top 90 TD5 2001
Ford 100e 1959
www.youtube.com/mikemakesit
Post #580210 24th Nov 2016 9:30pm
Remember if its centre is 600mm or less from the ground it can only legally be used in fog or falling snow.
Post #580271 24th Nov 2016 11:46pm
miker
Could work, someone on here has Hella fogs under the front bumper. Not sure how much useful light output you'd get from one that far down?
Post #580276 25th Nov 2016 12:11am
MC84
Forgot about the placement rules and I guess its not the best place to achieve max lighting benefit I suppose.
Any pics from roof mounted bar owners?? Thumbs Up Thumbs Up Mike
Ford 100e 1959
Post #580293 25th Nov 2016 4:15am
ericvv
I do. For fogs the light output is just perfect from that level. Think about it that the position of those fogs under a Defender bumper still is quite a bit higher than the factory fogs on many other cars. I would think that for a driving beam LED bar the under bumper position is too low though. Too much of its light beam will be reflected up by the tarmac close to the truck. Better position to have a driving beam would be above the bumper or integrated under the top side of a soft A-bar which already comes with the fittings for spots or a LED bar. That height is more or less the same as the main lights of the truck, which much better for driving lights.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #580295 25th Nov 2016 5:27am
DonH2000
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Santorini Black
Roof mounted light bars are probably only allowed "off road" due to being too high. Needs some one to check on legality of this..... Cheers Don.
Post #580334 25th Nov 2016 10:12am
There is no longer a max height limit for non-obligatory front lights, one of the few things, regulation-wise, for which we have the EU to thank.
Post #580350 25th Nov 2016 11:43am
MC84
A step in the right direction then blackwolf! Mike
Ford 100e 1959
Post #580357 25th Nov 2016 12:27pm
pjb
I have a shadow lightbeam bar that mounts at the top of the grill that you could mount a light bar too
http://www.defender2.net/forum/topic44480.html
Made by First Four
Its cluttering up the garage so would sell for £20 incl postage 2020 P300 HSE
Post #580358 25th Nov 2016 12:36pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
I think the most obvious problem with mounting a light bar underneath the bumper is that it's going to decrease your approach angle and be the first thing that hits the ground.
I know this is Defender 2, home of the tart's handbags but you can at least pretend to want some sort of off road consideration for a Defender Smile http://www.yorkshireoffroadclub.net/
Post #580363 25th Nov 2016 12:44pm
MC84
Made by First Four
PM sent.... Thumbs Up Mike
Ford 100e 1959
Post #580371 25th Nov 2016 1:08pm
huffhuff
United Kingdom 2001 Defender 90 Td5 HT Java Black
I didn't want to ruin my 'lines' either, so this is what I did... (if I could copyright or trademark the placement I would) Smile
 TD5 Defender 90
Discovery 3 HSE
Post #580429 25th Nov 2016 4:43pm
MC84
That looks good. There might be 2 around soon like that!!! Mike
Ford 100e 1959
Post #580433 25th Nov 2016 5:01pm
huffhuff
I can send some better pics if you like. But basically, you need to remove some of the heatsink fins at the back to account for the brace bars and wang on a couple of brackets Smile TD5 Defender 90
Discovery 3 HSE
Post #580434 25th Nov 2016 5:07pm
Birdy
France 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
"Defender 2, home of the tart's handbags"
How dare you, how very dare you. I've never been so insulted. Just because...
Peter
Post #580436 25th Nov 2016 5:16pm
