![]() | Home > Td5 > Under bumper TD5 LED light bar! Possible? |
MC84 Member Since: 23 May 2016 Location: Near Bristol Posts: 360 ![]() ![]() ![]() |
I'm sure I've seen magazine articles which had a light bar slung under the front bumper. Does anyone have links to any vehicles that have had these fitted please?
I don't really want to fit a light bar on the roof as I'd prefer to keep the profile I have. Mike Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1776 ![]() ![]() ![]() |
Could work, someone on here has Hella fogs under the front bumper. Not sure how much useful light output you'd get from one that far down?
Forgot about the placement rules and I guess its not the best place to achieve max lighting benefit I suppose.
Any pics from roof mounted bar owners?? ![]() ![]() Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit Last edited by MC84 on 25th Nov 2016 9:32am. Edited 1 time in total |
I do. For fogs the light output is just perfect from that level. Think about it that the position of those fogs under a Defender bumper still is quite a bit higher than the factory fogs on many other cars. I would think that for a driving beam LED bar the under bumper position is too low though. Too much of its light beam will be reflected up by the tarmac close to the truck. Better position to have a driving beam would be above the bumper or integrated under the top side of a soft A-bar which already comes with the fittings for spots or a LED bar. That height is more or less the same as the main lights of the truck, which much better for driving lights. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
DonH2000 Member Since: 12 Jan 2015 Location: North Kent Posts: 551 ![]() ![]() ![]() |
Roof mounted light bars are probably only allowed "off road" due to being too high. Needs some one to check on legality of this..... Cheers Don. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17729 ![]() ![]() ![]() |
There is no longer a max height limit for non-obligatory front lights, one of the few things, regulation-wise, for which we have the EU to thank.
A step in the right direction then blackwolf! Mike
pjb Member Since: 08 Apr 2009 Location: Sunny Oxford Posts: 1244 ![]() |
I have a shadow lightbeam bar that mounts at the top of the grill that you could mount a light bar too
http://www.defender2.net/forum/topic44480.html Made by First Four Its cluttering up the garage so would sell for £20 incl postage 2020 P300 HSE |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 ![]() ![]() ![]() |
I think the most obvious problem with mounting a light bar underneath the bumper is that it's going to decrease your approach angle and be the first thing that hits the ground.
I know this is Defender 2, home of the tart's handbags but you can at least pretend to want some sort of off road consideration for a Defender ![]() |
PM sent.... ![]() Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
huffhuff Member Since: 05 May 2016 Location: Home Counties Posts: 379 ![]() ![]() ![]() |
I didn't want to ruin my 'lines' either, so this is what I did... (if I could copyright or trademark the placement I would)
![]() ![]() Click image to enlarge ![]() Click image to enlarge TD5 Defender 90 Discovery 3 HSE |
That looks good. There might be 2 around soon like that!!! Mike
I can send some better pics if you like. But basically, you need to remove some of the heatsink fins at the back to account for the brace bars and wang on a couple of brackets
![]() Discovery 3 HSE Last edited by huffhuff on 25th Nov 2016 5:16pm. Edited 1 time in total |
Birdy Member Since: 07 Oct 2011 Location: Côte d'Azur Posts: 883 ![]() ![]() ![]() |
"Defender 2, home of the tart's handbags"
How dare you, how very dare you. I've never been so insulted. Just because... Peter |
