Home > Puma (Tdci) > Puma Exhaust Mod,...Not worth it? |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 |
I have a straight through from DPF back that cost a mere £150 fitted. Full stainless with a 3" tip.
Makes a bit more noise than normal but nothing major. Plus its still MOT compliant and i know its as free flowing as it can legally be. I wasn't too fussed about the power increase. I wanted more grunt, I probably to neither but for £150 it was worth a go, not 10x that amount 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
21st Nov 2016 8:37pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3650 |
replacing the centre box with a straight through pipe is worth doing just for the weight saving and reduction in cabin heat DEFENDER 90 TDCI XS,
21st Nov 2016 8:49pm |
Morepower Member Since: 08 Jan 2013 Location: Fife, Scotland Posts: 630 |
Some things to note... Although the peak power may only be slightly better... What is the spread like?... Also, What is the comparable time under graph?.. Peak numbers are only part of the story... Although £1200 does seem very expensive... I have Bowler systems on both the 110 and 90 and I think that was the combined cost for both..
Regards Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
21st Nov 2016 9:42pm |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3787 |
Standard & modified graphs are pretty much identical,..very minor differences throughout the rev range.
Pickles. |
21st Nov 2016 9:48pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2651 |
Remove cat and centre box, that should be a few quids at the local exhaust shop --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
22nd Nov 2016 7:40am |
Any chance we can see the graphs Pickles?
Cheers Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
23rd Nov 2016 5:52pm |
Best We can do, but I'm sure someone would be able to copy it from the mag better if you require it.
But you can see the torque & power curves,...virtually identical. Pickles. Click image to enlarge |
23rd Nov 2016 9:32pm |
Hi Pickles... I think you need to look more carefully at that graph... @2100 rpm where the turbo is starting to really get into it's stride the std system makes 96Hp and 104nm of torque... The replacement system makes 110hp and 111nm of torque this gain looks (obviously if the graph is correct) like it's mainly low down so I would expect that the system has less back pressure enabling the turbo to spool earlier. Interestingly its pretty much exactly where you need it as I myself don't rev either of the trucks pass about 3500rpm...and mostly alot lower as theres not much point going past 3000rpm
In real world terms this system would make a really noticeable difference to how the truck drove on the road... It would feel faster to respond to the 'throttle' input and quicker through the gears if you changed up at a more sensible 2500-2600 rpm or just after peak torque, That way the engine would be back in the area where the exhaust is giving the greatest benefit... In fact, just reading the description (I only looked at the graph ) I follows exactly the same conclusion as I have had using the Bowler systems...Both the 110 and the Bowler 90 are in stg 1.5 guise and are really nice to drive on the road. Regards Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
24th Nov 2016 6:45am |
No worrries, I hear what you say,...in that particular rev range, but over the rest of the range?.
However, that is as good as it gets, I believe that over the overall driving range/performance there would be very little in it. Regards, Pickles. |
24th Nov 2016 8:32am |
I think you'll find that you'd need a bigger turbo to have any meaningful gains further up the rev range... However, you would then probably run into crankshaft issues as the engine really isn't meant to rev'd like a petrol..
Trust me, On the road this would feel like a fairly noticeable gain. Regards Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
24th Nov 2016 8:21pm |
Manxie Member Since: 29 Oct 2016 Location: Isle Of Man Posts: 26 |
Does anyone have the answer to whether or not a certain amount of back pressure is advantageous? For example I've been told that you shouldn't remove the cat and center muffler due to "overspool", and that you should only remove one or the other....
25th Nov 2016 1:19pm |
Turbo dependant mainly.... some turbo's are designed to have an amount of back pressure, if this is removed then the seals can fail..
25th Nov 2016 5:04pm |
Does anyone know if this applies to the Puma engine?
25th Nov 2016 7:21pm |
Sadi Member Since: 23 Jul 2015 Location: Windhoek Posts: 334 |
Some interesting reading here:
http://www.myturbodiesel.com/wiki/turbocha...rbo-faq-2/ |
25th Nov 2016 9:28pm |
