![]() | Home > Maintenance & Modifications > Positive turbo pressure intake side |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
Hi guys,
Was setting up to do my timing belt today but events overtook themselves and I ended up doing some errands and then changing my oil. After changing the oil I checked out what had been a bit of a booming noise occasional which I managed to trace to the induction pipework. I suspected one of my piston rings had stuck or gapped or something and was causing pressure in the crankcase to be emitted into the rocker cover and air intake but i found very little if any to be present. What i did find however was that the turbo intake is pushing air out and in at the same time. Yes, weird. With the intake pipework intact, I removed the engine breather to the air filter body and found it to be pulsing. I removed the air intake pipework from the nose of the turbo (exposing the compressor) and with the engine running felt a positive pressure coming out of the compressor. So. why? Surely the intake side of the turbo should only suck? Any thoughts? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter ![]() |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
oh shaggy, welcome to my world
![]() i have had this issue for ages! motor runs fine so never really got to bottom of it. i suspect cam timing! i think the inlet is opening slightly too soon on the exhaust stroke! of course this is just a guess! My 109 thread my youtube channel |
I must admit I thought of you when I noticed it.
![]() Just seems counter intuitive, there should be no positive pressure there so its ether something blocking the pipework downwind of the turbo, the turbo centre seal is letting by (but no oil present?) or as you say its a timing issue but that would have more of an effect when removing the oil cap which it didnt. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter ![]() |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2735 ![]() ![]() |
Does it push air out of the turbo intake when it is off idle?
Yes. Seems to find equilibrium with some revs added and then just sucks in from then onwards. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Mine is only a nipper its only just clocked over 190k!
In that case I will apply steam engine fault finding to it. "If you hear an unfamiliar noise, listen to it until it becomes familiar, the noise is no longer a worry" Thanks guys! Timing belt tomorrow. Wish me luck ![]() Self confessed mileage hunter ![]() |
There's a very good pictorial guide on LR4x4 if you haven't seen it, worth a look.
