Home > Maintenance & Modifications > Positive turbo pressure intake side
shaggydog
Hi guys,
Was setting up to do my timing belt today but events overtook themselves and I ended up doing some errands and then changing my oil.
After changing the oil I checked out what had been a bit of a booming noise occasional which I managed to trace to the induction pipework.
I suspected one of my piston rings had stuck or gapped or something and was causing pressure in the crankcase to be emitted into the rocker cover and air intake but i found very little if any to be present.
What i did find however was that the turbo intake is pushing air out and in at the same time.
Yes, weird.
With the intake pipework intact, I removed the engine breather to the air filter body and found it to be pulsing.
I removed the air intake pipework from the nose of the turbo (exposing the compressor) and with the engine running felt a positive pressure coming out of the compressor.
So. why?
Surely the intake side of the turbo should only suck?
Any thoughts? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #579713 22nd Nov 2016 7:55pm
g-mack
oh shaggy, welcome to my world Laughing
i have had this issue for ages! motor runs fine so never really got to bottom of it. i suspect cam timing! i think the inlet is opening slightly too soon on the exhaust stroke!
of course this is just a guess! My 109 thread
my youtube channel
Post #579732 22nd Nov 2016 9:01pm
shaggydog
I must admit I thought of you when I noticed it. Laughing
Just seems counter intuitive, there should be no positive pressure there so its ether something blocking the pipework downwind of the turbo, the turbo centre seal is letting by (but no oil present?) or as you say its a timing issue but that would have more of an effect when removing the oil cap which it didnt. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #579742 22nd Nov 2016 9:41pm
Retroanaconda
Does it push air out of the turbo intake when it is off idle?
Post #579746 22nd Nov 2016 9:48pm
shaggydog
Yes. Seems to find equilibrium with some revs added and then just sucks in from then onwards. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #579748 22nd Nov 2016 9:51pm
Retroanaconda
I wouldn't worry about it then, even if it is a problem how often do you sit at those revs when driving?
I have noticed that my 200Tdi appears to 'chuff' air out of the air box drain hole at idle. No idea why, nor have I any idea why yours would do the same from the turbo, however moving air can do very weird things so there may be a simple explanation for it that someone cleverer than I could give us. For all I know mine might do the same as yours, next time I have the turbo pipe off I will give it a try.
Could be engine wear - mine has 274k on the clock so the rings are probably not in their original state, however it runs fine and returns good MPG so as long as that continues I'll not worry too much about it. I don't go chasing problems that might not even be there, I get enough real ones to keep me busy!
Post #579750 22nd Nov 2016 9:59pm
shaggydog
Mine is only a nipper its only just clocked over 190k!
In that case I will apply steam engine fault finding to it.
"If you hear an unfamiliar noise, listen to it until it becomes familiar, the noise is no longer a worry"
Thanks guys!
Timing belt tomorrow.
Wish me luck Shocked Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #579751 22nd Nov 2016 10:08pm
Retroanaconda
There's a very good pictorial guide on LR4x4 if you haven't seen it, worth a look.
Post #579809 23rd Nov 2016 9:52am
