Home > Technical > Seized calipers, opinions please.
Page 2 of 2 <12
Welkman
Thanks.
Post #579272 20th Nov 2016 7:58pm
agentmulder
Kuwait
Quick replies (I'm at work)
Bearmach OK for this, I've had a chance to compare to genuine. I'd be happy with them.
Split calipers, your decision, but be informed and Google 'torque to yeild bolt'.
Inter caliper seals still available for some (older?) caliper types. Solved the bowel problem, working on the consonants...
Post #579281 20th Nov 2016 8:35pm
Welkman
Ah I see, plastic deformation. It is a shame they dont sell new bolts really. I am also not sure that the bolts were anywhere near yield tight but then again I didnt design the calipers. I am going to grab a couple of new calipers anyway for the sake of getting the truck back on the road asap.
Post #579283 20th Nov 2016 8:41pm
shaggydog
I used Bearmach on mine in July and 10k miles later they are doing fine! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #579286 20th Nov 2016 8:47pm
Welkman
gone for a pair of bearmach for £100. They are zinc coated which seems like a better idea than the AP ones which hold on to the dirt!
Post #579290 20th Nov 2016 9:10pm
Vogler
Belgium 2015 Defender 110 Td5 HT Chawton White
I have refurbished the calipers of our 110 about a year ago and have split them and fitted stainless pistons. I picked up somewhere on the net that you should torque the caliper bolts to 70Nm. I think it was on the lr4x4 forum and it was based on the average force needed to undo them IIRC.
If you don't manage to remove corrosion in the cylinder bores with Scotchbrite, than you'd better replace the calipers.
I had to look around for the longer gallery seals (the o-rings between the halves) for the front calipers and found them at shop4autoparts. Mind that there's a small tube in them which is a separate part, take care not to throw it away!
Greetings,
Joris
Post #579302 20th Nov 2016 9:41pm
agentmulder
Kuwait
While that 70Nm may work fine, (and continues to do so in the case of my rear calipers) some of the engineering logic and assumptions behind it a bit spurious.
Beware that YMM(literally)V. Solved the bowel problem, working on the consonants...
Post #579341 20th Nov 2016 11:31pm
Morepower
New Zealand
Might be worth contacting the likes of Urban truck/twisted etc etc as they may have complete take off std brake kits. I managed to get a complete brake kit for a friend of mine... I picked up new disc's, pads and calipers front and rear at a very reasonable price...
It might be worth having a ring around and see who's got what.
Regards
Tim It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #579357 21st Nov 2016 7:24am
Merlin
Use stainless steel pistons from :
http://www.zeusengineering.co.uk/
I got all 12 for about £110.
Merlin
see:
http://www.defender2.net/forum/topic44921....l+calipers
Post #579459 21st Nov 2016 3:32pm
Vogler
Vogler wrote:
...I picked up somewhere on the net that you should torque the caliper bolts to 70Nm. I think it was on the lr4x4 forum and it was based on the average force needed to undo them IIRC...
Found the above mentioned thread on lr4x4: here
Greetings,
Joris
Post #579590 22nd Nov 2016 12:21am
Page 2 of 2 <12
