![]() | Home > My Defender > 130 - Tow machine |
Welkman Member Since: 02 Nov 2014 Location: Essex colchester Posts: 332 ![]() ![]() |
I wish I had a mate with a tig setup I could borrow ! Awesome build
Defender830 Member Since: 06 Nov 2016 Location: Somerset Posts: 5 ![]() ![]() ![]() |
Definitely the slash. Looks like an epic defender. Engineering skills are very impressive. Want to extend my 110 to 130. Just need to find the funds. More likely to win the lottery. Amazing job awesome. Keep up the posts.
Red8eard Member Since: 21 Oct 2016 Location: UK Posts: 69 ![]() ![]() |
Cheers guys really appreciate the support and input on here.
Been a bit cold to be out in the cattle shed so ive been working on other bits and pieces in the house Firstly a cover plate for the pneumatic valves to operate the high and lo and difflock on the transfer case. should look well on the transmission tunnel when i fab it. ![]() Click image to enlarge Also still not 100% on the exhaust so been playing with designs and ive narrowed it down to 2 now a straight 3" or a ellipse 3" leaning toward the ellipse atm Think it looks less agri spec ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Also received a delivery of a boost controller and a stainless 1/8 EGT boss to weld into the exhaust. Should help me get some more power out of the cummins reliably . ![]() Click image to enlarge Exhaust will be finished this weekend i hope fingers crossed ![]() -Ged |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10896 ![]() ![]() |
Agree with you there Ged, the way you are leaning on the choice of the exhaust and the cover plate looks spot on to me as well
Just a small update as my phone died due to the below freezing temps outside.
Got my puma bonnet fitted with a td5/300 gas strut kit from xcess 4x4 and modified it to suit. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Ill be taking it back off to sound deaden and tidy up my trimming lol -Ged |
Looks good there Ged, you cant beat a K&N filter
Cheers, they dont make a bigger one unfortunately lol going to make a mud and water shroud for it out of a bucket or something lol
Its been a tad cold over here in Ireland so apart from some welding and parts collecting in the hall ive gotton some video footage and chopped it into a short clip with some pictures. Enjoy Cheers, Ged Last edited by Red8eard on 27th Nov 2016 10:58pm. Edited 1 time in total |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2939 ![]() ![]() |
Class mate !!!
![]() 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Cheers, Pushing on through the cold with the exhaust saga now almost complete few springs to weld on to finish the slip joints as it too narrow for anything else.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Heres a quick video of it feeding the trees. https://www.youtube.com/watch?v=N3CrUt8IJ3E -Ged |
That noise
Very nice, nice exhaust exit and choice of cut
hehe im glad you approve, final bit of welding to do this week and it will be grand. Moved onto a few other jobs. biggest of which was tuning the engine.
Boost is now peaking at 2.7bar a little black smoke while on boost. Safe to say im at the limit of the hx35 and ill be leaving the power around there for a while. estimated around 300-350hp with the 3800rpm governor and sheadloads of torque. Engine and pump mods so far. 5.9 cummins HX35w turbo 12cm housing 3" inter cooler and pipework 3" exhaust +50 injectors VE static timing advance 1 tooth Boost pin Piston lift pump. video for the craic. I also fitted some sound deadening and completed the bonnet work. ![]() Click image to enlarge ![]() Click image to enlarge and started mocking up some ideas for the trans tunnel. ![]() Click image to enlarge MOT's now getting closer. Last edited by Red8eard on 27th Nov 2016 10:59pm. Edited 1 time in total |
Many steps forward there Ged
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1856 ![]() ![]() ![]() |
Looking amazing this build. Looking forward to hearing how it performs on and off the road.
Is that the Britpart bonnet kit? 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
