Home > Technical > Gearbox and diff oil
JamesF
United Kingdom 1989 Defender 90 2.5 TD HT Baltic Blue
Hi all
Can anyone tell me what oil I need to refill my gearbox and diffs on my 1998 Defender?
Also what size sockets will I need for the drain and refill plugs.
All very confusing Shocked but fun finding out. This forum is a mine of information although I do find myself scratching my head a bit lol
Post #577567 13th Nov 2016 7:01pm
Screbble
I'm guessing it's a TD5 with an R380 gearbox and std axles?
If so, you can use EP90 for both axles and the transfer box BUT not in the gearbox.
For the gearbox you need MTF94.
I recollect that a 1/2 drive will do most of it with a torx T55 for one of the fillers - but I can't remember without looking.
Contact Opie Oils - a forum sponsor here - they'll point you in the right direction and you'll get a forum discount Thumbs Up
Post #577603 13th Nov 2016 8:45pm
I think there's a typo in the OP and his 90 is an '89. In which case, it'll have an LT77 gearbox that uses ATF.
EP90 for the diffs and transfer box still, though. Darren
Post #577621 13th Nov 2016 9:21pm
Screbble
Ah yes Embarassed
Well spotted Thumbs Up
Post #577635 13th Nov 2016 9:39pm
JamesF
Thanks for the replies chaps and yes good spot. Fat fingers and small keys
Post #578916 19th Nov 2016 11:13am
Vogler
Belgium 2015 Defender 110 Td5 HT Chawton White
The plugs in the axles are 1/2" like the most common socket wrench.
The drain plug of the R380 is either a large hex (with a single use copper gasket ring) until 2004, or a 3/8" square like a medium socket wrench (on defenders at least). Tight space, a 1/2" socket with adapter to 3/8" won't fit unless you remove the drive shaft at the gearbox. Don't overtighten when refitting them, especially the drain plug. Despite having taken care the last time, I'm now struggling with it and have 'unsquared' the hole in doing so.
Make sure to check first if you can unscrew the filler plugs.
Good luck in dodging the oil Wink
Post #578926 19th Nov 2016 12:01pm
JamesF
Thanks
I will check that.
thanks for the heads up. Just hope my head does not end up covered in oil!
Post #579638 22nd Nov 2016 10:20am
