Home > Puma (Tdci) > Boost and EGT Guage Installs
big110
2014 Defender 110 Puma 2.2 SW Keswick Green
Doing lots of searching and reading- but looking for the best methods to hard wire (as in I do not want OBDII blue tooth app etc). Would like to install both a Boost guage as well as EGT monitor guage. I have had these in other TDI vehicles and like to know whats going on.
anyone have a write up of an install?
Post #576528 9th Nov 2016 2:41pm
Cupboard
You don't have to have a phone app for displaying the OBD information, something like an Ultraguage will mount in the little gap in the middle of the instrument cluster and display all sorts of interesting information. Looks very neat and works well.
However nothing will display EGT because it's not monitored on the Defender so you'll have to add your own sensor.
Post #576584 9th Nov 2016 6:57pm
Roy5695
EGT can be measured on the 2.2 with an ultragauge as it has two temp sensors pre and post DPF, this is how I know mine is regenerating and not to turn it off. Also measures cylinder head temperature...
Also mounted it inside the clocks... 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #576708 9th Nov 2016 11:35pm
Roy5695
You can see the EGT here, as CAT C
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #576709 9th Nov 2016 11:41pm
Manxie
Isle Of Man 2008 Defender 110 Puma 2.4 HT Keswick Green
I just ordered one of these today from Redarc, they get very good reviews and are quite unique in how the work as an LCD screen, they are also metric on the EGT in degC, and in PSI for boost, which I like. https://www.redarc.com.au/monitoring-gauges-g52-bea
Post #577394 12th Nov 2016 8:44pm
toby9946
United Kingdom 2015 Defender 90 Puma 2.2 Landmark LE Corris Grey
How do you mount the Ultraguage inside the dash? Is there a guide somewhere as I haven't found anything? -2015 Defender 90 XS Landmark-
Post #577427 12th Nov 2016 11:19pm
Defender2014
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Santorini Black
Found this.
Looks like a fair bit of work.....
http://defender90xs.blogspot.co.uk/2014/09...ation.html Defender Puma 110XS SW
Kawasaki ZX9R El
Suzuki RGV250M
Honda CB250N Super Dream
Post #577473 13th Nov 2016 10:25am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
It's not as bad as it looks, just a bit delicate.
Well worth the effort though.
Here's how mine turned out.. Wink
 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #577475 13th Nov 2016 10:34am
Cupboard
Your fuel level - is it picking it up through the actual fuel sender or doing guesswork based on the MAF?
Post #577498 13th Nov 2016 2:23pm
