![]() | Home > Td5 > Problems!!!! |
Alien Member Since: 18 Jan 2015 Location: Bacchus Marsh Posts: 230 ![]() ![]() |
To help diagnose(which is hard when it can't been seen or heard)a little more information may help.
Has the idle changed? Does it rev OK when stationery? If the throttle is used gently can it get road speed OK? Has it had an over heating incident? Any recent mechanical work done to it? A common issue is for a intercooler hose to delaminate internally restricting airflow when under load. Loss of power and black smoke are the usual symptoms. I had one hose develop a crack so it lost boost pressure with the foot down hard, wouldn't pull and eventually blew smoke as it got worse. Cheers Kyle. Cheers, Kyle. |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 ![]() ![]() ![]() |
I would start off by unplugging the MAF and see if that makes a difference.
Is the engine warning light coming on ? (If so it could be going into limp home mode) Have you checked all the pipework, especially intercooler pipes, are secure ? (I've had intercooler pipes pop off before and that turns it into a very poor normally aspirated engine.) Is it a rev limit where it's running out of power as revs increase or is it road speed related ? (There's a hard limit that cost in at a set road speed if you're in low box, or the ECU thinks you are). http://www.yorkshireoffroadclub.net/ |
Deerfold Member Since: 28 Aug 2016 Location: Shropshire Hills Posts: 54 ![]() ![]() ![]() |
Yes it is as if it has rev limit, it can get to speed, just.
Unplugged the maf and no difference. Checked all pipe work which is all silicone updated No engine warning light. |
Have you checked the air intake and filter?
As it's had a new MAF maybe a rag was left in the airbox? Cheers, Kyle. |
Yup, air intake, filter and induction pipework is all good. I am thinking as it's had a new injector loom as well it's a head gasket?
huffhuff Member Since: 05 May 2016 Location: Home Counties Posts: 379 ![]() ![]() ![]() |
Limp mode/overboost? Sticky waste gate? TD5 Defender 90
Discovery 3 HSE |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 ![]() ![]() ![]() |
Have you checked boost pipes and intercooler for leaks
Sounds most probable 2008 110 2.4 XS Utility (Hagrid) 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
AndyT66 Member Since: 19 Sep 2016 Location: Bedford Posts: 149 ![]() ![]() ![]() |
Have you pulled the red plug on the ecu to check for oil, I had a similar issue on a 53 plate and needed a new injector harness, all sorted after that
alwoodley72 Member Since: 14 Mar 2010 Location: salisbury, wilts Posts: 726 ![]() ![]() ![]() |
Map sensor on the inlet, I had the same symptoms on my disco when I swapped heads, changed to old sensor and it went like a stabbed rat again. Temp gauge ok?
Cheers alex 98 300 tdi 90 project 94 Range Rover vogue 4.2 lse 79 911 sc 08 130 double cab utility |
Super7 Member Since: 05 Feb 2014 Location: South Bucks. Posts: 135 ![]() ![]() ![]() |
Have you checked the EGR valve?
I had similar problems with mine, and the EGR valve was completely clogged up. I replaced it with a blanking kit, and been fine since ![]() '52 Series 1 80" '99 Caterham 7 |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 ![]() ![]() ![]() |
can you hear the fuel pump with the ignition on? mine will run without a fuel pump but it is very slow and won't rev hard 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r |
