Home > Td5 > Problems!!!!
Deerfold
United Kingdom 2004 Defender 90 Td5 HT Caledonian Blue
Problems!!!!
Hello all, I am after some advice. My partners 54 plate TD5 has suddenly lost power, in all gears foot to the floor the truck is acting like it's against a limiter, in the dark it looks like it's smoking. Marginal water loss, possible system pressure as it looks like coolant has pressurised out of the header. Oil looks ok. I think I can hear an engine bay ticking that I don't notice from before. Turbo is spooling up, new maf recently and I do need to do a warped exhaust manifold at some point, but this is only a minor front stud blow, all studs still intact. Any thoughts really appreciated.
Post #576137 7th Nov 2016 10:00pm
Alien
Australia
To help diagnose(which is hard when it can't been seen or heard)a little more information may help.
Has the idle changed?
Does it rev OK when stationery?
If the throttle is used gently can it get road speed OK?
Has it had an over heating incident?
Any recent mechanical work done to it?
A common issue is for a intercooler hose to delaminate internally restricting airflow when under load.
Loss of power and black smoke are the usual symptoms.
I had one hose develop a crack so it lost boost pressure with the foot down hard, wouldn't pull and eventually blew smoke as it got worse.
Cheers Kyle. Cheers,
Kyle.
Post #576140 7th Nov 2016 10:18pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
I would start off by unplugging the MAF and see if that makes a difference.
Is the engine warning light coming on ? (If so it could be going into limp home mode)
Have you checked all the pipework, especially intercooler pipes, are secure ? (I've had intercooler pipes pop off before and that turns it into a very poor normally aspirated engine.)
Is it a rev limit where it's running out of power as revs increase or is it road speed related ? (There's a hard limit that cost in at a set road speed if you're in low box, or the ECU thinks you are). http://www.yorkshireoffroadclub.net/
Post #576141 7th Nov 2016 10:18pm
Deerfold
Yes it is as if it has rev limit, it can get to speed, just.
Unplugged the maf and no difference.
Checked all pipe work which is all silicone updated
No engine warning light.
Post #576143 7th Nov 2016 10:31pm
Alien
Australia
Have you checked the air intake and filter?
As it's had a new MAF maybe a rag was left in the airbox? Cheers,
Kyle.
Post #576150 7th Nov 2016 10:46pm
Deerfold
Yup, air intake, filter and induction pipework is all good. I am thinking as it's had a new injector loom as well it's a head gasket?
Post #576154 7th Nov 2016 11:04pm
huffhuff
United Kingdom 2001 Defender 90 Td5 HT Java Black
Limp mode/overboost? Sticky waste gate? TD5 Defender 90
Discovery 3 HSE
Post #576280 8th Nov 2016 3:59pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Have you checked boost pipes and intercooler for leaks
Sounds most probable 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #576339 8th Nov 2016 7:20pm
AndyT66
England 2004 Defender 90 2.5 TD XS CSW Zambezi Silver
Have you pulled the red plug on the ecu to check for oil, I had a similar issue on a 53 plate and needed a new injector harness, all sorted after that
Post #576396 8th Nov 2016 10:30pm
alwoodley72
England 2008 Defender 130 Puma 2.4 HCPU Alaska White
Map sensor on the inlet, I had the same symptoms on my disco when I swapped heads, changed to old sensor and it went like a stabbed rat again. Temp gauge ok?
Cheers alex 98 300 tdi 90 project
94 Range Rover vogue 4.2 lse
79 911 sc
08 130 double cab utility
Post #576427 8th Nov 2016 11:54pm
Super7
United Kingdom 1999 Defender 90 Td5 CSW Rutland Red
Have you checked the EGR valve?
I had similar problems with mine, and the EGR valve was completely clogged up. I replaced it with a blanking kit, and been fine since Thumbs Up '99 TD5 Defender 90
'52 Series 1 80"
'99 Caterham 7
Post #576494 9th Nov 2016 11:37am
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
can you hear the fuel pump with the ignition on? mine will run without a fuel pump but it is very slow and won't rev hard 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #576574 9th Nov 2016 6:20pm
