Home > Technical > 2006 TD5
Paulv8
1989 Defender 90 V8 Petrol CSW Alpine White
2006 TD5
HI guys, gonna look at a 2006 TD5 tomorrow. A couple of questions if you could help?
Do the later TD5s have the newer style doors as standard? I thought that was only for the ford engined models?
This car has a replacement exhaust - should it have a CAT in it?
Cheers fellas.
Paul V8 90...WIP
Post #575106 3rd Nov 2016 8:51am
dorsetsmith
If it has round top door they newer style doors with steel shin and gav frames as do my 06 TD5 pickup
Post #575111 3rd Nov 2016 9:14am
Vogler
Belgium 2015 Defender 110 Td5 HT Chawton White
Two years ago we bought our 2005 Td5 which is a MY06 according to the VIN. It has the later style doors, and originally should have had a cat too.
The car had 80k km /50k m and since we bought it, I had to do the following things apart from maintenance:
- Transfer box jumped out of low gear, fortunately just the hi-low gear linkage needed adjustment.
- Recondition the calipers and replace the brake discs
- Rectify the warped exhaust manifold. You might have experienced it on your Discovery. If not: it makes a screeching sound in the higher revs, lika a swallow on steroids. I could also notice soot staining at the rear of the manifold where the studs were loose (and not broken fortunately)
- Replace rear halfshafts and all flanges
- Replace injector harness. The oil had reached the ECU
- Replace the belt, tensioner and follower
- Replace main clutch cylinder
- Small leak on the FPR (not fixed yet)
- Replace contacts of the starter motor
The chassis contained quite some sand and crud.
The doors are cracked next to the private lock. You can't see it but you''ll notice that the upper part of the interior moves a bit outward of the glass
FWIW: Although it is a 15p, I checked the oil pump bolt last weekend and was happy to see that it was still firmly attached. I did notice a leak at the PAS pump and between the turbo oil return pipe.
Also there's play in the transfer box since 10k km.
That's all probably more than our 1995 BMW needed/suffered from until now in its 333k lifetime Rolling Eyes
Regards,
Joris
Post #575116 3rd Nov 2016 9:42am
Vogler
Edited - Aargh, double post, wifi hiccup...
J
Post #575117 3rd Nov 2016 9:42am
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
I have a 2005 Td5 which has the newer type doors fitted I believe late 04/05 was the year they started fitting them.
Yes an 06 plate would have had a Cat fitted when new.
Kind Regards
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #575132 3rd Nov 2016 12:17pm
Paulv8
Thanks guys.... it doesnt matter now as the Censored sold it... V8 90...WIP
Post #575133 3rd Nov 2016 12:20pm
