Home > Puma (Tdci) > Rust on random bits
defender75
2009 Defender 110 Puma 2.4 XS CSW Chawton White
Rust on random bits
Been looking around under the hood. I posted this in another thread. Just wondering why some of this stuff would rust.
Truck only has 500 or so miles. It is an 09 that sat for awhile but just wondering.
thanks
Post #57305 7th Feb 2011 3:33am
lrdxb110
United Arab Emirates 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
its a defender Laughing
Rust is covered under warranty, just get your dealer to have it replaced. '08 LR Defender 110
'08 Mini Cooper S - Sidewalk
'86 MB 500 SL
'79 MB 450SEL 6.9
Post #57308 7th Feb 2011 5:57am
defender75
they would replace the turbo and manifold for surface rust?
What is the other thing?
Post #57311 7th Feb 2011 6:29am
Caterham
off at a tanget here....your engine lifting point is red ?
not sure I've noticed one of these in red before?
and re; the rust I think you might struggle to get them replaced - albeit it looks naff and they should (mind you for the few pennies you think they'd do it right in the first place!) - good luck.
Post #57316 7th Feb 2011 8:55am
RED-DOT
Every hot side of every turbo in the world will rust.. cast iron and salty damp air dont mix.. as for getting it replaced don't even try! 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #57331 7th Feb 2011 10:56am
LCJ
Dont think I've had a Defender where those bits haven't grown rust, although picture two looks a bit more extreme.
I wouldn't be worried about rust there.
Post #57365 7th Feb 2011 1:52pm
dgardel
Italy
Please, please, please............. NO ALLARM!!!!!
Turbo housing, common rail main collector and engine block are made on cast iron!!!!!
ALL engine maker do it in cast iron!!! (or in alloy, but cast iron block are more stronger) ALL exhaust manifold (turbo housing is a part of) are made in cast iron (or stainless steel in same bike and ultrasport car) and it taken "rust color" but it is only a color!!!!
Cast iron is like stainless steel, it produce an surface oxidation (brown color on cast iron) but IT ISN'T RUST CORROSION!!!!
In the past same engine maker painted the cast iron engine block, but now, for costs cutting reasons nobody do it!!!
look the engine block of a Discovery 4 new!!!! the same BUT IT ISN'T RUST CORROSION!!!!!
So if you go to the Dealer........
you only make an ugly "figure"...............
You can cover or remove the rust on the common rail collector (only for cosmetics reasons) by OWATROL or similar rust inhibitor fluids....................... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #57371 7th Feb 2011 2:09pm
defender75
what is a common rail collector and thanks for the info
Post #57407 7th Feb 2011 4:24pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Middle picture Thumbs Up Original Member Pie n Pea Club.
110 HCPU Tipper
Post #57408 7th Feb 2011 4:25pm
dgardel
Italy
The "rusty" Twisted Evil collectors where start the small metal pipes to the injectors, middle pictures like "willy eckerslike" said.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #57450 7th Feb 2011 6:47pm
defender75
I assume that thing rusting is normal as well?
Post #57476 7th Feb 2011 7:33pm
dgardel
Italy
YES!!!! Thumbs Up Thumbs Up Thumbs Up  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #57483 7th Feb 2011 7:48pm
K9F
Bow down Dgardel you are the veritable 'Master of the Rust' Laughing Couldn't say Rustmaster due to copyrights! Probably! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #57503 7th Feb 2011 8:27pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
If you really don't like it then wire wool and High Temp: Engine/Manifold paint will restore the factory look. Won't make any overall difference however and it will come back as the paint will eventually burn off.
Post #57505 7th Feb 2011 8:31pm
mse
Why hasnt someone mentioned search Rolling with laughter
But yes its very normal!! Mike
Post #57530 7th Feb 2011 9:14pm
