Home > Puma (Tdci) > Rust on random bits
Page 2 of 2 <12
K9F
mse wrote:
Why hasnt someone mentioned search Rolling with laughter
But yes its very normal!!
Nearly did Mike! You know me!!! Rolling with laughter If you go through life with your head in the sand....all people will see is an ar5e!!
Post #57534 7th Feb 2011 9:19pm
defender75
2009 Defender 110 Puma 2.4 XS CSW Chawton White
knew that was coming
Post #57553 7th Feb 2011 10:04pm
dgardel
Italy
WelshGas wrote:
If you really don't like it then wire wool and High Temp: Engine/Manifold paint will restore the factory look. Won't make any overall difference however and it will come back as the paint will eventually burn off.
At least using 800°C resistant paint Whistle Whistle Whistle Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #57561 7th Feb 2011 10:28pm
dgardel
Italy
K9F wrote:
Bow down Dgardel you are the veritable 'Master of the Rust' Laughing Couldn't say Rustmaster due to copyrights! Probably! Thumbs Up
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #57563 7th Feb 2011 10:29pm
mse
Mr. Green Mike
Post #57588 7th Feb 2011 11:20pm
Grockle
I'm having my fuel rail,engine block and turbo colour matched to the body Thumbs Up 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #57627 8th Feb 2011 9:10am
mse
I heard painting in red made the car go faster...is that also true Rolling with laughter Mike
Post #57635 8th Feb 2011 9:32am
JSG
Only safe to do that if you uprate the braking system by painting the calipers red so you can stop better too .. John
2011 Tdci 110 CSW XS
Post #57651 8th Feb 2011 10:56am
mse
got you Rolling with laughter Thumbs Up Mike
Post #57735 8th Feb 2011 5:46pm
Page 2 of 2 <12
