![]() | Home > Technical > 110 DCPU vs 130 DCPU |
1978 Member Since: 04 Aug 2015 Location: Lancashire Posts: 519 ![]() ![]() ![]() |
There are lots of dimensions here.....
http://topix.landrover.jlrext.com/topix/se...367/en_GB? But probably not the ones you need! |
RFT Member Since: 13 Nov 2010 Location: Cheshire Posts: 685 ![]() ![]() ![]() |
As far as I recall the 110 DCPU is not a High capacity PU whereas the 130 DCPU is a High capacity as such the chassis, suspension etc differ. 130 Puma HCPU with an Artica 240LR Demountable Camper
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5884 ![]() ![]() ![]() |
Some good measurements there but not quite what I am looking for.
I have had a crazy idea of building a 130 DC with a flat deck and putting a Harvey Frost on the back for rally recovery. (save towing one around) might never happen but finding info is always useful 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17600 ![]() ![]() ![]() |
There is approx 24" extra bed length on a 130 DCPU over a 110 DCPU. I cannot remember by how much the 130 rear buck overhangs the rear crossmember, however, so I can't tell you the bare chassis length difference.
excossack
You can measure up my 130, I'm normally near Helsby, Stanlow or Heswall in Wirral. Richard 130 Puma HCPU with an Artica 240LR Demountable Camper |
Hi RFT
Heswall would be good if we can arrange some time? My 110 in for a new bulkhead at the mo. ta. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
I'll let you know when I am visiting my Mum in Heswall.
I'll send PM Richard 130 Puma HCPU with an Artica 240LR Demountable Camper |
The 130 tub is shorter than a 110 HCPU tub but longer and wider than a 110 DCPU tub.
http://www.landroverweb.com/Pdf-files/Land...nsions.pdf |
Thanks. Just wondering what you really gain in a 130 vs a 110 ? 1999 Defender TD5 110
If you follow the link I posted:
Bed length in mm: 110 PU: 1901 110 HCPU: 2010 110 DCPU: 1020 130 DCHCPU: 1829 So you're gaining 32" bed space, of which some (17") is from the wheelbase and the rest (15") is from a greater rear overhang. I assume a chassis cab will be similar, but you can also get 130 single cab chassis cabs. |
