Home > Technical > 110 DCPU vs 130 DCPU
excossack
Apart from 20" extra in the wheel base, if you had 110 DCPU and 130 DCPU with no rear tubs on either(so a bare chassis) how much extra would you gain in rear bed space? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #570580 13th Oct 2016 11:11am
1978
United Kingdom 2003 Defender 90 Td5 HT Belize Green
There are lots of dimensions here.....
http://topix.landrover.jlrext.com/topix/se...367/en_GB?
But probably not the ones you need!
Post #570581 13th Oct 2016 11:16am
RFT
United Kingdom 2010 Defender 130 Puma 2.4 HCPU Zermatt Silver
As far as I recall the 110 DCPU is not a High capacity PU whereas the 130 DCPU is a High capacity as such the chassis, suspension etc differ. 130 Puma HCPU with an Artica 240LR Demountable Camper
Post #570603 13th Oct 2016 12:41pm
excossack
Some good measurements there but not quite what I am looking for.
I have had a crazy idea of building a 130 DC with a flat deck and putting a Harvey Frost on the back for rally recovery. (save towing one around) might never happen but finding info is always useful 1999 Defender TD5 110
Regards
John M0VAZ
Post #570605 13th Oct 2016 12:47pm
There is approx 24" extra bed length on a 130 DCPU over a 110 DCPU. I cannot remember by how much the 130 rear buck overhangs the rear crossmember, however, so I can't tell you the bare chassis length difference.
Post #570607 13th Oct 2016 1:13pm
RFT
excossack
You can measure up my 130, I'm normally near Helsby, Stanlow or Heswall in Wirral.
Richard 130 Puma HCPU with an Artica 240LR Demountable Camper
Post #570610 13th Oct 2016 1:34pm
excossack
Hi RFT
Heswall would be good if we can arrange some time? My 110 in for a new bulkhead at the mo.
ta. 1999 Defender TD5 110
Regards
John M0VAZ
Post #570620 13th Oct 2016 2:10pm
RFT
I'll let you know when I am visiting my Mum in Heswall.
I'll send PM
Post #570652 13th Oct 2016 4:15pm
Cupboard
The 130 tub is shorter than a 110 HCPU tub but longer and wider than a 110 DCPU tub.
http://www.landroverweb.com/Pdf-files/Land...nsions.pdf
Post #571363 16th Oct 2016 8:36pm
excossack
Thanks. Just wondering what you really gain in a 130 vs a 110 ? 1999 Defender TD5 110
Regards
John M0VAZ
Post #571489 17th Oct 2016 12:31pm
Cupboard
If you follow the link I posted:
Bed length in mm:
110 PU: 1901
110 HCPU: 2010
110 DCPU: 1020
130 DCHCPU: 1829
So you're gaining 32" bed space, of which some (17") is from the wheelbase and the rest (15") is from a greater rear overhang. I assume a chassis cab will be similar, but you can also get 130 single cab chassis cabs.
Post #571510 17th Oct 2016 2:25pm
