Home > Technical > Bonnet Keeps Suddenly Springing Up |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4225 |
Sounds like the bonnet catch itself is sticking, damaged or our of alignment. I'd give it a good dowsing in spray grease. Lock and release the bonnet a few times to get the grease worked. 2007 110 TDCi Station Wagon XS
15th Oct 2016 7:41am |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 742 |
Thanks, Bluest. Will give that a go!
17th Oct 2016 1:58am |
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 248 |
My Austin-Rover mini did that after I had the bonnet off. I made a few adjustments to the striker plate as the thing on the bonnet with the pin/spring was not going into it properly. If it is lined up ok (remove grill and look from underneath) then that pin/spring arrangement on the bonnet itself may need a bit of adjustment (i.e. tightening to compress the spring)
Its the same setup as on the mini. 1953 80" 1987 mini city e 2011 90" |
19th Oct 2016 8:57pm |
Thanks for the tip, MR_JAMES!
Will take a look while I'm changing out the VCV. |
20th Oct 2016 2:23am |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1799 |
Get someone to hold the release handle open
The pin on the bonnet should pass cleanly though the exact centre of the catch. Adjust the catch on the bonnet and slam panel until you achieve this You may even have to adjust the bonnet hinges too if required Then look at the catch, the ,gate, should be full across when closed, fully open when pulled, adjust cable to get this correct Then adjust the centre pin out almost as much as it can go Adjust the rubber buffers to give clearance on the wings Then tighten the centre pin until it removes most of the free play and the bonnet is secure Keith |
20th Oct 2016 7:53am |
Bluebay Member Since: 25 Aug 2015 Location: Sheffield Posts: 9 |
Also worth checking the end of the pin attached to the bonnet to see if it's worn.Could be a sign of someone being under the bonnet a lot doing repairs
28th Oct 2016 4:19pm |
Just to update everyone, I had some work done and told them about my little problem, they adjusted the bit on the bonnet with the spring. Used a spanner and a flat head screwdriver. After the adjustment, bonnet stays down now.
28th Nov 2016 2:44am |
