Home > Technical > Softer Springs
TheJollyBodger
Softer Springs
Hi All,
I currently use my trailer (pic below) to transport my telescoping gear and camping gear when we go away.
The problem I'm having is as the trailer is made from the rear end of a Defender with all the running gear still intact- the springs are rated for the weight of a full 90 so that I find the trailer "bounces" over potholes etc which makes me worry about some of the expensive gear I transport in it.
Can anyone recommend a "softer" spring that I can swap on to which should soak up some of the lumps and bumps?
Post #570413 12th Oct 2016 8:17pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Assuming they are standard 90 rear springs, they are rated at 225 ft/lbs.
Standard 90 front springs are a straight swap, and rated at 175 ft/lbs.
You could fit earlier Discovery 1 standard [Not HD] front springs too ... these are rated at 150 ft/lbs, but are about an inch taller so will give a slight lift.
If buying springs, go for used genuine if you can. In my experience, most aftermarket spring rates are all over the place!
Every 'standard' set of Britpart I've fitted has given the motor a noticeable lift and stiffen Evil or Very Mad
Hope that helps Wink Guns and Landrovers .... anything else is irrelevant.
Post #570425 12th Oct 2016 8:46pm
TheJollyBodger
That's great Dave, thanks. I have a set of standard fronts in storage I could try. Are they longer though / give a lift?
Post #570526 13th Oct 2016 9:52am
Dave-H
More or less the same length ... 90 front/rear/left/right only vary [when new] by barely half an inch or so .. Wink Guns and Landrovers .... anything else is irrelevant.
Post #570641 13th Oct 2016 4:13pm
Devon-Rover
Blue stripe springs (RR / Disco V8 front) Are only 130Ilbft rated if you need softer. Any thing else less then you might have to investigate custom made versions.
Post #570684 13th Oct 2016 7:55pm
TheJollyBodger
That's great guys thanks.
I'm going to a chap this weekend who can fit some air springs which may be better so if it's not too expensive I'll look at that as an option.
Otherwise I'll try the original fronts I took off my puma, then the Disco 1 set if not soft enough.
Post #570779 14th Oct 2016 9:36am
Doubledoom
United Kingdom 2016 Defender 90 Puma 2.2 SW Santorini Black
That is a great looking trailer. Really good job. Hope the springs work out for you. Adjustments: Startech Steering Wheel | MUD Interior LED lights | Wipac crystal headlights with osram nightbreaker bulbs | Alpine CDE195BT
To do list: Outside rear facing LED lighting | subwoofer and speakers
Post #570788 14th Oct 2016 10:51am
TheJollyBodger
Cheers, I'm making up a tool box / easy access box for the A frame out of chequer plate this weekend and also fitting some heavy duty Gas struts to the lid. Bloody Land Rovers are addictive!
Post #570790 14th Oct 2016 10:54am
