![]() | Home > Maintenance & Modifications > Added another layer. Aerocatches.. |
ROBBONTHEROCK Member Since: 23 Jun 2014 Location: Aberdeenshire Posts: 637 ![]() ![]() ![]() |
Hi there,
Just wondering if these brackets are still available to buy? I'm looking for a pair for my new aerocatchs ![]() Am watching the video now ![]() Cheers Andy |
Pinky Member Since: 09 Jun 2016 Location: England Posts: 210 ![]() ![]() ![]() |
Just looked on eBay and he still has some..
Perfecto - thanks, have bought a pair
![]() Cheers Andy |
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 ![]() ![]() ![]() |
Missed this first time around. What an excellent way to make your Defender, and itīs easy to remove bonnet, less attractive to thieves.
![]() Can someone point me in the direction of the brackets on ebay? 1998 Tdi 90 SW, 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MTīs, Recaro CSīs, anorak, wellingtons |
No problemo:-
Bracket:- eBay item number:282196631951 Aerocatch:- eBay item number:301137883797 Cheers AndyR |
Hi All,
Will the aerocatchs hold the bonnet on, or do they merely provide a physical lock? I have a GRP bonnet, and whoever fitted the bonnet made it squint, so i was intending to delete the centre securing catch and the bonnet latch itself (which is causing the twist) and re-align the bonnet hinges, and relying on the aerocatchs itself. Any info would be good ![]() Cheers Andy |
![]() 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MTīs, Recaro CSīs, anorak, wellingtons |
ace, looks like i'll be tackling that this weekend
![]() Cheers Andy |
I have them fitted and yes, they would hold the bonnet without the catch. The pins are quite substantial and lock positively. I think they are probably designed for use without the catch in motorsport.
So can I adjust them so that the pull the bonnet down onto itself?
I trying to combat the natural twist in my GRP bonnet...... Fingers crossed ![]() Cheers Andy |
They are adjustable up and down but once the brackets are fitted you need to make sure the bonnet is really where you want it before cutting the holes as there is no lateral adjustment.
I fitted the brackets, installed the pins leaving them sticking up high, put a tiny dot of paint right on the top and gently closed the bonnet. The paint gave me the centre point to drill. |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1309 ![]() ![]() ![]() |
I got the brackets for the pins. Haven't worked up the courage yet to take the drill to the bonnet.
