Home > In Car Electronics > Trailer tell-tale light |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17355 |
The obvious question: when you're towing do the trailer indicators work?
11th Oct 2016 9:18pm |
PumaPhil Member Since: 26 Oct 2014 Location: Bridgend Posts: 201 |
Forgot to mention that! Yes, the indicators on the trailers are working. The same trailers make the tell tale light on another 2015 defender flash as it should do.
11th Oct 2016 9:29pm |
That's wierd!
Can you try swapping the flasher relay over with the other Defender? |
11th Oct 2016 10:04pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20304 |
Are trailer lights incandescent or LED? ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
11th Oct 2016 10:43pm |
I had a bit of this the other day when I was servicing a trailer for a friend, when I turned the lights on there was a bleed trough to all the lights, every bulb was lit, lights off indicators on and they also made all the other bulbs glow dimly on each flash. but the tell tale wasn't working.
After a set to on the trailer plug, a clean up and open the pins up a bit it all went away and everything worked as normal, including the tell tale on the dash. I'd suggest that you either change the socket on your motor, as it has the same effect on which ever trailer you tow, or take it apart and give it a good clean. 90% of trailer light problems are due to the socket/plug. |
12th Oct 2016 10:36am |
Thanks all for your replies.
Blackwolf- that other Defender has been changed for a commercial Discovery! Custom 90 - both. Of the 3 trailers used regularly 1. About 10 years old with incandescent lamps and a 7 pin plug, no signal to the tell tale at all. 2. Has brand new wiring with LED lamps and a 7 pin plug. No signal to the tell tale. 3. A brand new trailer, incandescent lamps, 13 pin plug. Today it was working perfectly turning right, but nothing turning left! JWL - I think I'll give cleaning the 13 pin socket on the Defender a good clean, and also the 13 to 7 pin adapter I use. |
12th Oct 2016 7:54pm |
Try adding a temp earth too whilst your at it and see if there is any difference. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
12th Oct 2016 8:26pm |
