Home > Off Topic > Stone cutting discs..? |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 |
Hello couplands
Done a lot of this and tried these... <£30.00 each so not cheap but did go the distance (on the plus side its a sign of how good your mortar is... ) https://www.orbitalfasteners.co.uk/en/prod...0wod8kUH3w SKIP https://www.defender2.net/forum/topic83242.html |
6th Oct 2016 12:52pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3708 |
Sounds about right, Abacras are a good quality. Dont buy from Aldi or B&Q go to a tool supplier or a tool hire company.
Have you tried the diamond discs? 130's have feeling's as well you know |
6th Oct 2016 12:54pm |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 |
Thanks Skip, it might explain why the last blade only lasted 45mins....it only cost me a Fiver...
Cheers Simon |
6th Oct 2016 12:55pm |
The last one I had was a diamond disc, from a local tool store...but cheap. How long should I expect quality blade to last with continuous use ( and Skip, my mortar isn't that hard otherwise I wouldn't be raking it out..) Cheers Simon |
6th Oct 2016 12:58pm |
trial and error in technique also...tip...washing up liquid on blade every so often can help, brush out 'slots' if clogged
I re-pointed our whole house...bought 20 of the diamond discs (£500) used all but 5, I got 1/2 a days use before changing SKIP https://www.defender2.net/forum/topic83242.html |
6th Oct 2016 12:59pm |
Get a Mortar Rake they come in various Ø you can get an adapter to go onto a grinder.
Get the one with 3 or 4 blades. Also get a decent face mask glasses and gloves http://www.transtools.co.uk/construction-t...raker-10mm 130's have feeling's as well you know |
6th Oct 2016 1:11pm |
6th Oct 2016 1:15pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20430 |
If you stick to disc definitely recommend Bosch diamond, mine on a small cordless will go through concrete like butter.
Smaller or larger they are great, go for notched too like to link above not a solid disc as they are for finer cutting like tiles etc. $W33T $0U7H3RN $UG4R 🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
6th Oct 2016 3:08pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3643 |
ditto diamond loads better than abrasive grit types DEFENDER 90 TDCI XS,
6th Oct 2016 4:30pm |
