Home > Off Topic > Stone cutting discs..?
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
I'm currently grinding out the mortar between the slabs on my patio and getting though a disc (115mm dia) in about 45mins.
Any recommendations for a make that might be better quality than mine..? I was hoping the discs would last a bit longer, or am I being too optimistic..?
Simon
Post #569122 6th Oct 2016 1:38pm
X4SKP
Hello couplands
Done a lot of this and tried these... <£30.00 each so not cheap but did go the distance
(on the plus side its a sign of how good your mortar is... Shocked )
https://www.orbitalfasteners.co.uk/en/prod...0wod8kUH3w SKIP
Post #569124 6th Oct 2016 1:52pm
AndrewS
Sounds about right, Abacras are a good quality. Dont buy from Aldi or B&Q go to a tool supplier or a tool hire company.
Have you tried the diamond discs? 130's have feeling's as well you know Smile
Post #569126 6th Oct 2016 1:54pm
couplands
Thanks Skip, it might explain why the last blade only lasted 45mins....it only cost me a Fiver... Shocked
Simon
Post #569127 6th Oct 2016 1:55pm
couplands
The last one I had was a diamond disc, from a local tool store...but cheap.
How long should I expect quality blade to last with continuous use ( and Skip, my mortar isn't that hard otherwise I wouldn't be raking it out..Smile)
Simon
Post #569128 6th Oct 2016 1:58pm
X4SKP
trial and error in technique also...tip...washing up liquid on blade every so often can help, brush out 'slots' if clogged
I re-pointed our whole house...bought 20 of the diamond discs (£500) used all but 5, I got 1/2 a days use before changing SKIP
Post #569129 6th Oct 2016 1:59pm
AndrewS
Get a Mortar Rake they come in various Ψ you can get an adapter to go onto a grinder.
Get the one with 3 or 4 blades.
Also get a decent face mask glasses and gloves
http://www.transtools.co.uk/construction-t...raker-10mm 130's have feeling's as well you know Smile
Post #569134 6th Oct 2016 2:11pm
AndrewS
Post #569136 6th Oct 2016 2:15pm
If you stick to disc definitely recommend Bosch diamond, mine on a small cordless will go through concrete like butter.
Smaller or larger they are great, go for notched too like to link above not a solid disc as they are for finer cutting like tiles etc.
Thumbs Up WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #569149 6th Oct 2016 4:08pm
LR90XS2011
ditto diamond loads better than abrasive grit types DEFENDER 90 TDCI XS,
Post #569155 6th Oct 2016 5:30pm
