Home > Td5 > Tinkling/rattling sound when taking foot of the gas at 70-60
CamRSA
United Kingdom 2004 Defender 110 Td5 DCPU Alaska White
Hey guys,
Yet another weird noise coming from Arnold. Today I noticed when I take my foot off the gas from 70 to 65-60 there is a weird sound of something tinkering around, like a toolbox when you shake it. Its quite faint and coming from either centre or drivers side.
Any suggestions as to what it could be? I still have the wobbling at 55mph so this is another addition. Didn't notice it at other speeds.
Post #568262 2nd Oct 2016 6:10pm
ppad
United Kingdom 2005 Defender 90 Td5 HT Caledonian Blue
Gearbox? I've had the same thing, noise, decelerating from speed after the box had got properly warm.
Seemed to me that the bearings were rattling. So I ignored it ... on the 2005 truck these last 3 years and 20k miles driving to and from Switzerland in 30C for 12 hr at a time with the whole centre tunnel glowing red hot (more or less Rolling Eyes ) ... and it's still going fine. Drive it. When (if) it stops, fix it Thumbs Up Sold the much modified 110 2.8, in Oz
Brought the 90 home from Switzerland ...
Post #568329 2nd Oct 2016 9:06pm
JWL
Might not be but check the heat shield by the turbo, they often fracture around the fixing points.
Post #568331 2nd Oct 2016 9:12pm
Hufflepuff
Check the thin metal heat shield on the passenger side gearbox mount. I had what sounds like a similar tinkling sound to what you have described, which happened at certain engine RPMs, and it turned out to be this little metal heatshield which is designed (I assume) to protect the rubber mount from the exhaust temperature. You can easily bend it, so see if its able to rattle against any metal parts.
Post #568516 3rd Oct 2016 10:08pm
familymad
I have this noise. Watching the thread with interest. Same speeds too. 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #568578 4th Oct 2016 11:46am
Ken B
+1 same noise and cannot identify where it comes from, it only occurs when lifting off the accelerator at 65+ ish mph Defender 90 TD5 County -
You need only two tools in life: WD-40 and duct tape.
If it doesnt move and it should: WD-40.
If it moves and shouldnt: duct tape it.
Post #568701 4th Oct 2016 7:57pm
TechnoTurkey
2005 Defender 110 Td5 CSW Zambezi Silver
+1 again for a similar noise when easing off at high speed, only happened a few times though.
Post #568814 5th Oct 2016 8:24am
CamRSA
Bizarre. 1hour drive today and always at the same speed when taking foot off the pedal.
Post #569490 8th Oct 2016 1:14pm
