![]() | Home > Tdi > Cant select diff lock or Low |
Your linkages are most likely seized die to lack of use, if they are fully clear of mud and dirt inspect them to ensure they are not snapped (does happen a lot) and they are not loose, if all that is good you can try to select low box, have it in first gear and slowly raise the clutch as you keep a steady pressure on the lever, do not try and force it too hard or you may snap the linkage. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
Deane Thomas Member Since: 04 Sep 2016 Location: Cheshunt, Hertforshire Posts: 8 ![]() ![]() |
Thanks will look closer tomorrow. It feels as though the lever is already as far forward as possible but still only in neutral, is it possible that a previous owner has not assembled the linkage properly? The lever is almost touching the gear stick?? Sorry to appear a total idiot by the way!!
Huttopia Member Since: 23 Feb 2016 Location: West Midlands Posts: 1978 ![]() ![]() |
What model / variant are you driving?
1989 90 with refurbed 300tdi from disco 1.
Ok, my 1996 90 300tdi isn't the easiest to get into low range. Leaving it in gear I have to take it out of low into 'nothing' then up with the clutch, wait a second or two, down again and then it will go in. I've got a rough idea that isn't text book but it seems to work ok.
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
are you rolling while trying? i find it much easier to slowly roll forward then slip into low
![]() my youtube channel |
Thanks for the tips and suggestions, I will find time later today to try them out and will post results.
