Home > Tdi > Cant select diff lock or Low
Deane Thomas
Greenlaining for the first time tis weekend and could not select Low or switch to lock, removed cover and sprayed wd40 everywhere, still no joy. I can select Neutral and assume its constantly in high. Is there a quick and easy way to diagnose the problem? Sorry for not knowing any technical references.
Post #566752 26th Sep 2016 4:41pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Your linkages are most likely seized die to lack of use, if they are fully clear of mud and dirt inspect them to ensure they are not snapped (does happen a lot) and they are not loose, if all that is good you can try to select low box, have it in first gear and slowly raise the clutch as you keep a steady pressure on the lever, do not try and force it too hard or you may snap the linkage. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #566798 26th Sep 2016 7:37pm
Deane Thomas
Thanks will look closer tomorrow. It feels as though the lever is already as far forward as possible but still only in neutral, is it possible that a previous owner has not assembled the linkage properly? The lever is almost touching the gear stick?? Sorry to appear a total idiot by the way!!
Post #566801 26th Sep 2016 7:47pm
Huttopia
What model / variant are you driving?
Post #566835 26th Sep 2016 8:40pm
Deane Thomas
1989 90 with refurbed 300tdi from disco 1.
Post #566838 26th Sep 2016 8:43pm
Huttopia
Ok, my 1996 90 300tdi isn't the easiest to get into low range. Leaving it in gear I have to take it out of low into 'nothing' then up with the clutch, wait a second or two, down again and then it will go in. I've got a rough idea that isn't text book but it seems to work ok.
Post #566845 26th Sep 2016 8:51pm
g-mack
are you rolling while trying? i find it much easier to slowly roll forward then slip into low Thumbs Up My 109 thread
my youtube channel
Post #566896 27th Sep 2016 7:28am
Deane Thomas
Thanks for the tips and suggestions, I will find time later today to try them out and will post results.
Post #566908 27th Sep 2016 8:19am
