Page 947 of 1378 <123 ... 946947948 ... 137613771378>
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
New experience in the 110 2.2 today. Pillock came zooming out of a junction and did not see me as I had just set off from parking by the road. Anyhow, I floored it in 2nd to give us space and again in 3rd and heard a horrible noise in both gears. what the F I thought until I realised I must have hit the rev limiter in both gears. First time in this car.
Question is when does the rev limiter cut in?
Post #565416 20th Sep 2016 5:23pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
got to use the motorbike because a pillock in a horse box hit the side of my 90 and it's in a body shop all week... 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #565461 20th Sep 2016 8:47pm
Fairly insignificant really but at long last I got the SS headlight fixing kit bought and arrived today.
Just sort out some LED headlights in due course and possibly Land Reziger loom. Whistle
 $W33T $0U7H3RN $UG4R
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #565960 22nd Sep 2016 10:24pm
if you are fitting LED headlights, there's no point fitting the loom ... LED headlights operate from 9-18v and draw about 35watts Thumbs Up
Post #566003 23rd Sep 2016 9:03am
How about possible voltage loss though? Surely that still has an effect all be it most likely on a much lesser scale. $W33T $0U7H3RN $UG4R
Post #566009 23rd Sep 2016 9:41am
DefenderJon
Northern Ireland 2000 Defender 90 Td5 CSW Epsom Green
After fitting new front calipers and pads, and overhauling the rear calipers for the last MOT, I still wasn't completely happy with my brakes. Did the 'pump, then start' test this morning and the pedal didn't drop with the engine running. I then checked the servo, and found a crack around the area where the top nut mounts the master cylinder to the servo.
A nice new TRW servo is now in it's place, and my brakes are awesome!!
I'd recommend anyone who thinks their braking may be a bit 'off' to check their servo. A nice easy 20 minute fix.
Jon. Defender 90 TD5 CSW - The longer I own it, the newer it gets!!
Post #566073 23rd Sep 2016 2:11pm
Hairysteve
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Barolo Black
Fitted the following Gwyn Lewis products and am very pleased Very Happy
X members shields - http://www.gwynlewis4x4.co.uk/product/land...epped-tub/
Extended Front Mud Flap Mounting Kit & Mud Shields & Mud Flaps - http://www.gwynlewis4x4.co.uk/product/land...0-rtc4685/
Post #566112 23rd Sep 2016 5:56pm
nosnibod
United Kingdom 1998 Defender 110 300 Tdi SW Bronze Green
Makes no difference at all. The majority of LED headlights are regulated internally - i.e. they reduce the incoming voltage/current t that needed by the LEDs and the electronics. That's why some are rated from 9V to 24V.
I fitted LED headlights (Nolden) and side/tail/indicators (RDX) not only because they provide better illumination, but also because the head and side lights reduce the current draw through the main headlight switch.
I have had a headlight switch melt and now carry a spare under the drivers seat, together with a few other items that I've had fail such as the white plug on the bottom of the fuel filter. Oh and duct tape and zip ties... Dave
Green Goddess - 1998 Defender 110 300tdi
Post #566115 23rd Sep 2016 6:01pm
Nosnibod - Reduced current through switch can only be seen as a good thing, significantly lower current draw in fact. Thumbs Up $W33T $0U7H3RN $UG4R
Post #566119 23rd Sep 2016 6:29pm
nosnibod
Meant to add that the switch I had melt was before I fitted the LEDs. I can't remember the figures now but I remember working out that it roughly halved the current through the switch.
When I got our new 110 last year I swapped all the lights to LEDs immediately. After a while I didn't like the J W Speaker Evo 2 'look' (I kept them after trading in our old 110) so swapped to Noldens.
I really must put the Evo 2s up for sale soon - they've been sat in the garage for a year Whistle Dave
Post #566123 23rd Sep 2016 6:46pm
Yes, half current draw sounds about right and was what I was thinking as a guesstimate.
I like the Noldens too, I don't doubt the quality abd output but the price is still hefty.
Saying that, I'd rather that than bet say £200 on eBay and possibly have a damp squid on your hands. $W33T $0U7H3RN $UG4R
Post #566124 23rd Sep 2016 6:53pm
bm52
Which is the switch that can melt...the lights on switch or the dip beam switch?
Thanks
Post #566130 23rd Sep 2016 7:46pm
excossack
Popped into the paint shop on the way home to see the new bulkhead. Two pics I managed to get
and
Bulkhead has had the seams sealed before painting to try and keep as much out of the panel gaps as possible.
Just need to inject with cavity wax next. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #566133 23rd Sep 2016 7:57pm
nosnibod
Both Shocked
it seems the main light switch is the most likely one. That's the one I melted before swapping to LEDs. Dave
Post #566151 23rd Sep 2016 8:45pm
bm52
Thanks.
Switch or loom? It's still under warranty so not sure at the moment. But i always have the headlights on and winter is coming!!
Post #566153 23rd Sep 2016 8:47pm
