Home > My Defender > What Did You Do In Your Defender Today |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 |
got to use the motorbike because a pillock in a horse box hit the side of my 90 and it's in a body shop all week... 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r |
20th Sep 2016 8:47pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20480 |
Fairly insignificant really but at long last I got the SS headlight fixing kit bought and arrived today.
Just sort out some LED headlights in due course and possibly Land Reziger loom. Click image to enlarge No Guts, No Glory. 🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
22nd Sep 2016 10:24pm |
if you are fitting LED headlights, there's no point fitting the loom ... LED headlights operate from 9-18v and draw about 35watts
23rd Sep 2016 9:03am |
How about possible voltage loss though? Surely that still has an effect all be it most likely on a much lesser scale. No Guts, No Glory.
23rd Sep 2016 9:41am |
DefenderJon Member Since: 01 Dec 2012 Location: Sunny Ulster Posts: 68 |
After fitting new front calipers and pads, and overhauling the rear calipers for the last MOT, I still wasn't completely happy with my brakes. Did the 'pump, then start' test this morning and the pedal didn't drop with the engine running. I then checked the servo, and found a crack around the area where the top nut mounts the master cylinder to the servo.
A nice new TRW servo is now in it's place, and my brakes are awesome!! I'd recommend anyone who thinks their braking may be a bit 'off' to check their servo. A nice easy 20 minute fix. Jon. Defender 90 TD5 CSW - The longer I own it, the newer it gets!! |
23rd Sep 2016 2:11pm |
Hairysteve Member Since: 15 Jun 2015 Location: Surrey Posts: 692 |
Fitted the following Gwyn Lewis products and am very pleased
X members shields - http://www.gwynlewis4x4.co.uk/product/land...epped-tub/ Extended Front Mud Flap Mounting Kit & Mud Shields & Mud Flaps - http://www.gwynlewis4x4.co.uk/product/land...0-rtc4685/ |
23rd Sep 2016 5:56pm |
nosnibod Member Since: 15 Aug 2007 Location: West Midlands Posts: 370 |
Makes no difference at all. The majority of LED headlights are regulated internally - i.e. they reduce the incoming voltage/current t that needed by the LEDs and the electronics. That's why some are rated from 9V to 24V. I fitted LED headlights (Nolden) and side/tail/indicators (RDX) not only because they provide better illumination, but also because the head and side lights reduce the current draw through the main headlight switch. I have had a headlight switch melt and now carry a spare under the drivers seat, together with a few other items that I've had fail such as the white plug on the bottom of the fuel filter. Oh and duct tape and zip ties... Dave Green Goddess - 1998 Defender 110 300tdi |
23rd Sep 2016 6:01pm |
Nosnibod - Reduced current through switch can only be seen as a good thing, significantly lower current draw in fact. No Guts, No Glory.
23rd Sep 2016 6:29pm |
Meant to add that the switch I had melt was before I fitted the LEDs. I can't remember the figures now but I remember working out that it roughly halved the current through the switch.
When I got our new 110 last year I swapped all the lights to LEDs immediately. After a while I didn't like the J W Speaker Evo 2 'look' (I kept them after trading in our old 110) so swapped to Noldens. I really must put the Evo 2s up for sale soon - they've been sat in the garage for a year Dave Green Goddess - 1998 Defender 110 300tdi |
23rd Sep 2016 6:46pm |
Yes, half current draw sounds about right and was what I was thinking as a guesstimate.
I like the Noldens too, I don't doubt the quality abd output but the price is still hefty. Saying that, I'd rather that than bet say £200 on eBay and possibly have a damp squid on your hands. No Guts, No Glory. 🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
23rd Sep 2016 6:53pm |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
Which is the switch that can melt...the lights on switch or the dip beam switch?
Thanks |
23rd Sep 2016 7:46pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5862 |
Popped into the paint shop on the way home to see the new bulkhead. Two pics I managed to get
Click image to enlarge and Click image to enlarge Bulkhead has had the seams sealed before painting to try and keep as much out of the panel gaps as possible. Just need to inject with cavity wax next. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
23rd Sep 2016 7:57pm |
Both it seems the main light switch is the most likely one. That's the one I melted before swapping to LEDs. Dave Green Goddess - 1998 Defender 110 300tdi |
23rd Sep 2016 8:45pm |
Thanks.
Switch or loom? It's still under warranty so not sure at the moment. But i always have the headlights on and winter is coming!! |
23rd Sep 2016 8:47pm |
