Home > Td5 > Turbo issues
Bjornxxx
Sweden 2004 Defender 110 Td5 SW Java Black
Turbo issues
Discovered an oil leak on my 04 TD5. There is coming a little smoke and a burnt oil smell from the turbo after driving.
Also on start up, its like the turbo does not work until i drove 20-30 meters.
Any suggestions where i should start to look? Liks to diy guides etc?
Thanks
Post #565562 21st Sep 2016 11:37am
jst
send some pics of oil leak Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #565575 21st Sep 2016 1:11pm
Bjornxxx
Could I be so lucky that its the seal for the return pipe? In that case, how do I change it? Any diy guides availible? Should i bleed it somehow?
Is it the same gaskets for all Gt20 turbos? In that case I could probably order it here in Sweden!
Post #565601 21st Sep 2016 5:07pm
dorsetsmith
Post #565620 21st Sep 2016 7:02pm
rallysteve
Looks like the turbine side shaft seals gone to me sadly
Post #565636 21st Sep 2016 7:34pm
Bjornxxx
What can you tell this from? And how much will it cost me to repair?
Post #565638 21st Sep 2016 7:37pm
mk1collector
Looks like return pipe gasket gone and oil blown back by the fan to me. Ray
My build thread
Post #565649 21st Sep 2016 8:04pm
Fatboy Slim
Wales
Return pipe gasket and your airflow meters knackered
Post #565666 21st Sep 2016 8:26pm
jst
how far up does that oil go on the side? all the way around? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #565668 21st Sep 2016 8:30pm
Fatboy Slim
Wales
Order: 1x PNT100030 gasket, 1x MHK100620, fit them both and have a beer.
Post #565684 21st Sep 2016 9:13pm
Bjornxxx
jst: only on the side not all around.
I will order the gasket and change it. How big of a headache is this? I think I can access the bolt pretty easily, but then? Will I be able to move the pipe enough to fit the gasket?
The MAF I will look at the price, and try to clean it.
Then I will take a beer as you suggest!
Post #565753 22nd Sep 2016 9:10am
Fatboy Slim
Wales
Very Happy return pipe gasket is pretty easy to do. I wouldn't waste valuable beer drinking time on cleaning the maf. It's dead. Chuck a new one on it Thumbs Up
Post #565858 22nd Sep 2016 7:20pm
bifterx
United Kingdom 2004 Defender 110 Td5 DCPU Oslo Blue
That could have been a pic of my truck.
Have the same pRoblem . I tested the MAF with a multimeter = dead.
Fitted new MAF last Friday and cleaned the MAP sensor (which was pretty gunked up). MAde a huge difference, less smoke, smoother, feels much more solid. Got the same oil prob on the turbomreturn pipe (as well as the rocker breather at both ends) took the intercooler out today (which was a complete b**** to get out as my truck has aircon and the previous mechanic has hidden all the jubilee and banjo clip releases underneath the hoses) but dry as a bone and clean so didn't bother to flush but fitted silicone hoses whilst out.
I've got a gasket kit from paddocks to do the oil return and other turbo gaskets so that's next weekend and have a look at the turbo condition as the same time - so I'm hoping that'll do it Whistle Disco 300TDi XS - Gone
Disco 3 SE manual - Gone 😭
Freelander 2 SE manual
Defender 110 TD5 DC
Post #566613 25th Sep 2016 9:04pm
JWL
At least changing your gasket looks a little easier than it was on mine. Waste oil in the same place as your photo so ordered the seal, I got two just in case plus the motor factors were having a little difficulty getting one from their supplier Bearmach (genuine LR ones came in the end in pretty LR bags)
I've got a few things in the way, Eberspacher fuel tank and winch solonoid amongst others, so an open view wasn't possible and work had to be done by feel. I spent ages digging out all my Allen keys, Torx sockets as all I could feel was what felt like a fixing head with a hole in it. 20 minutes later, trying to take photos as I hadn't got a mirror it turned out that the bolt had fallen out on that side! I still had to take it all off as I needed the other bolt as a pattern to get a replacement Whistle
Post #566696 26th Sep 2016 12:34pm
Raywin
United Kingdom 2001 Defender 90 Td5 HT Java Black
The return pipe gasket is a bit fiddly but it is very cheap so why not.
It would not affect performance though, it just oozes oil onto the engine, looking at the picture seems to be oil higher than the gasket, but maybe this is blown there by the cooling fan, the heat shield ducts the air over the turbo. Ray
Post #566914 27th Sep 2016 8:45am
