Home > Maintenance & Modifications > Have I got the (correct) horn? |
Got a bit of time to tinker with my new 90 yesterday and began by tidying up the battery box. The battery is quite small so the clamp wasn't holding it properly and there were a mass of random wires, some of which weren't connected to anything. I think it's had spotlights fitted in the past that have since been removed but all of the wiring left in place.
Sorted the clamp easily enough and set about removing surplus wires, which included some that were traced to an air horn that was cabled tied to the air filter Removed the lot and threw it away. I ran out of time to do any more but I did notice that one standard horn was fitted behind the grill on the passenger side. Is that standard for this age of vehicle or should there be two - a high and low, one on either side? Thanks in advance. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
5th Sep 2016 8:15am |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
Never seen two on a TDI unless retrofitted ... They usually just have the one ... Guns and Landrovers .... anything else is irrelevant.
5th Sep 2016 1:31pm |
Great, thank you. Just got to reinstate the wiring in that case. Darren
5th Sep 2016 1:42pm |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 |
Just confirm that passenger side behind the grill is correct position for factory Tdi Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter |
6th Sep 2016 11:37am |
Brilliant, thank you. Darren
6th Sep 2016 11:49am |
Photo for reference.
Let me know if you need any other reference photos and I will see what I can do Click image to enlarge Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
6th Sep 2016 12:15pm |
Thanks I did notice that yours is the same vintage (and colour) as mine, Darren
6th Sep 2016 1:30pm |
Mine has 2 horns, same position as shaggy dog's, but under each other. Seems genuine. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
6th Sep 2016 3:06pm |
Thanks, but yours is a later and higher spec model. Darren
6th Sep 2016 6:12pm |
