Home > Maintenance & Modifications > Have I got the (correct) horn?
Got a bit of time to tinker with my new 90 yesterday and began by tidying up the battery box. The battery is quite small so the clamp wasn't holding it properly and there were a mass of random wires, some of which weren't connected to anything. I think it's had spotlights fitted in the past that have since been removed but all of the wiring left in place.
Sorted the clamp easily enough and set about removing surplus wires, which included some that were traced to an air horn that was cabled tied to the air filter Rolling Eyes Removed the lot and threw it away.
I ran out of time to do any more but I did notice that one standard horn was fitted behind the grill on the passenger side. Is that standard for this age of vehicle or should there be two - a high and low, one on either side?
Thanks in advance. Darren
Post #561504 5th Sep 2016 8:15am
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Never seen two on a TDI unless retrofitted ... They usually just have the one ... Guns and Landrovers .... anything else is irrelevant.
Post #561578 5th Sep 2016 1:31pm
Great, thank you. Just got to reinstate the wiring in that case. Darren
Post #561580 5th Sep 2016 1:42pm
shaggydog
Just confirm that passenger side behind the grill is correct position for factory Tdi Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #561826 6th Sep 2016 11:37am
Brilliant, thank you. Darren
Post #561833 6th Sep 2016 11:49am
shaggydog
Photo for reference.
Let me know if you need any other reference photos and I will see what I can do Very Happy
Post #561840 6th Sep 2016 12:15pm
Thanks Smile I did notice that yours is the same vintage (and colour) as mine, Darren
Post #561853 6th Sep 2016 1:30pm
VeeTee
Netherlands
Mine has 2 horns, same position as shaggy dog's, but under each other. Seems genuine. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #561873 6th Sep 2016 3:06pm
Thanks, but yours is a later and higher spec model. Darren
Post #561933 6th Sep 2016 6:12pm
