Home > Technical > Removing transfer lever on Puma |
Thanks,
The SVX one is definately different. The lower portion (below the knob) can indeed be pulled down the shaft. It does not have the plastic sheathing and you can see a partial threaded portion at the base of the knob itself. I suspect the SVX knob is threaded and secured in place with some form of thread lock. Understandably I have no desire to use any tooling to try to undo it as I do not wish to risk damage to the gear knob, or the transfer lever mechanism itself. I have no other option but a 'swap out.' Thankfully Dgardel has come to the rescue. (Again.... ) He has e-mailed me a comprehensive step by step guide on how to remove/replace the transfer lever. Thanks for getting back Matt..... If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
14th Sep 2012 12:09pm |
Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
14th Sep 2012 1:05pm |
That's Britpart for you...
Put in some DIY shim material? Solved the bowel problem, working on the consonants... |
24th Aug 2016 1:26am |
DEF_Jam Member Since: 17 Jul 2011 Location: Milan Posts: 59 |
I need to remove the transfer lever knob from my SVX. Could you please share the instructions? |
10th Aug 2024 4:13pm |
