![]() | Home > Technical > Removing transfer lever on Puma |
Thanks,
The SVX one is definately different. The lower portion (below the knob) can indeed be pulled down the shaft. It does not have the plastic sheathing and you can see a partial threaded portion at the base of the knob itself. I suspect the SVX knob is threaded and secured in place with some form of thread lock. Understandably I have no desire to use any tooling to try to undo it as I do not wish to risk damage to the gear knob, or the transfer lever mechanism itself. I have no other option but a 'swap out.' Thankfully Dgardel has come to the rescue. (Again.... ![]() Thanks for getting back Matt..... ![]() Treat every day as if it is your last....one day you will be right!! |
![]() ![]() IID Pro MV License |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
That's Britpart for you...
Put in some DIY shim material? Solved the bowel problem, working on the consonants... |
DEF_Jam Member Since: 17 Jul 2011 Location: Milan Posts: 59 ![]() ![]() ![]() |
I need to remove the transfer lever knob from my SVX. Could you please share the instructions? |
