Home > Maintenance & Modifications > Washer jets & Bosch Aero wipers. |
Lew-M Member Since: 04 Apr 2016 Location: North West Posts: 95 |
I use the aeros, very good and I think they last longer too, at the same time as looking a bit neater in my opinion
10th Aug 2016 1:42pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6603 |
I had AR13U blades but couldn't get the front jets to squirt neatly without hitting the (fatter) blade. I've gone back to the traditional type as the jet goes through gap between the frame and blade 1988 90 Td5 NAS soft top
2015 D90 XS SW |
10th Aug 2016 3:26pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20292 |
^^^^ So we've swapped over then Martin.
10th Aug 2016 4:34pm |
HowieB Member Since: 09 Jul 2016 Location: East Sussex Posts: 11 |
I have recentry changed to the aeros. Think they are better but have found the passenger side catches the rubber edge at the bottom of the windscreen on the up stroke. It makes an irritating sound!
At a recent service the dealer said this was due to these blades being longer; anyone else have this issue? Howard |
13th Aug 2016 6:20pm |
Not on mine that I've noticed, the wipers should not be near the screen rubber at all.
Are your wipers fairly aligned when parked out of use? If not could be wear, mine sit ever so slightly down and so do most often or nit. The extent at which though can show you how much wear is present. How many miles have you done? |
13th Aug 2016 8:50pm |
Thanks for reply.
The car is one year old and has done 8k miles. The blades are a few weeks old and look aligned and square. It has been back to the dealer for some work on the paint around the windscreen about one month ago for corrosion / bubbling. Wonder if they have done something when completing the work / putting it back together. I will pick up some standard blades and see if I have the same problem. H |
14th Aug 2016 6:27pm |
They may well have removed the wiper arms and adjusted them so that their screen sweep is lower than it should be.
If the wipers sit level I think that could well be the likelyhood. Blaming the wipers is an easy excuse.. _____________________________________________________________ Today, I fitted the new washer jet on the rear. All is good, both jets now work and adjusted so the old one was knackered. Glad that is sorted and only for under a tenner genuine. |
15th Aug 2016 3:43pm |
HowieB - Any update at all with your issue or have you not had the chance to give it a go yet?
_________________________________________________________________________________________ On a different note, today as it was raining I had my first use of the Bosch Aero's. Combined with Rain X applied to glass as well. They are brilliant, even better than the standard. Absolutely silent! I'd imagine that with such a smooth sweep there would be less wear and effort for the wiper motors too. Can only be a good thing! Replaced the rear washer jet the other day, it now sprays through both nozzles instead of just one. All good, was nice to see a genuine LR part 'made in UK' as well. Very pleased now. |
20th Aug 2016 9:36pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10731 |
Hi Steve, did anyone come forward and take your old bosch wiper blades from you ? 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
20th Aug 2016 10:01pm |
They did indeed.
20th Aug 2016 10:02pm |
never mind, will have to buy new then 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
20th Aug 2016 10:08pm |
If I'd have known..
The Aeros aren't bad at £22 for all three, less for just the front. Would you like a link to where I got mine from? Best price I could find they were. |
20th Aug 2016 10:27pm |
No worries Steve, i always sit on the fence for a while Yes please Steve, not a bad price at all, just for the front 2 please as i haven't got a back wiper I also use Rain X on all off my glass, inside as well 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
20th Aug 2016 10:33pm |
20th Aug 2016 10:35pm |
