Home > Maintenance & Modifications > Washer jets & Bosch Aero wipers.
Page 2 of 3 <123>
Lew-M
England 2012 Defender 90 Puma 2.2 HT Keswick Green
I use the aeros, very good and I think they last longer too, at the same time as looking a bit neater in my opinion Thumbs Up
Post #555046 10th Aug 2016 2:42pm
Martin
Site Admin
I had AR13U blades but couldn't get the front jets to squirt neatly without hitting the (fatter) blade. I've gone back to the traditional type as the jet goes through gap between the frame and blade Cool  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #555071 10th Aug 2016 4:26pm
^^^^ Rolling with laughter So we've swapped over then Martin. Thumbs Up
Post #555086 10th Aug 2016 5:34pm
For reference for others I got a new rear washer jet, genuine from Dan @ Duckworth parts.
Here it is and P/N.
Just thought I'd snap a photo for others.
Need to swap it over shortly now.
Post #555572 12th Aug 2016 2:18pm
HowieB
United Kingdom 2015 Defender 90 Puma 2.2 Landmark LE Corris Grey
I have recentry changed to the aeros. Think they are better but have found the passenger side catches the rubber edge at the bottom of the windscreen on the up stroke. It makes an irritating sound!
At a recent service the dealer said this was due to these blades being longer; anyone else have this issue?
Howard
Post #555794 13th Aug 2016 7:20pm
Not on mine that I've noticed, the wipers should not be near the screen rubber at all.
Are your wipers fairly aligned when parked out of use?
If not could be wear, mine sit ever so slightly down and so do most often or nit.
The extent at which though can show you how much wear is present.
How many miles have you done?
Post #555832 13th Aug 2016 9:50pm
HowieB
Thanks for reply.
The car is one year old and has done 8k miles.
The blades are a few weeks old and look aligned and square.
It has been back to the dealer for some work on the paint around the windscreen about one month ago for corrosion / bubbling. Wonder if they have done something when completing the work / putting it back together.
I will pick up some standard blades and see if I have the same problem.
H
Post #556007 14th Aug 2016 7:27pm
They may well have removed the wiper arms and adjusted them so that their screen sweep is lower than it should be.
If the wipers sit level I think that could well be the likelyhood.
Blaming the wipers is an easy excuse..
_____________________________________________________________
Today, I fitted the new washer jet on the rear.
All is good, both jets now work and adjusted so the old one was knackered.
Glad that is sorted and only for under a tenner genuine.
Post #556204 15th Aug 2016 4:43pm
HowieB - Any update at all with your issue or have you not had the chance to give it a go yet?
_________________________________________________________________________________________
On a different note, today as it was raining I had my first use of the Bosch Aero's.
Combined with Rain X applied to glass as well.
They are brilliant, even better than the standard. Absolutely silent!
I'd imagine that with such a smooth sweep there would be less wear and effort for the wiper motors too.
Can only be a good thing!
Replaced the rear washer jet the other day, it now sprays through both nozzles instead of just one. Rolling Eyes
All good, was nice to see a genuine LR part 'made in UK' as well.
Very pleased now. Mr. Green
Post #557568 20th Aug 2016 10:36pm
L110CDL
Hi Steve, did anyone come forward and take your old bosch wiper blades from you ? Clayton.
Keeper.
Post #557574 20th Aug 2016 11:01pm
They did indeed. Thumbs Up
Post #557576 20th Aug 2016 11:02pm
L110CDL
Sad never mind, will have to buy new then Thumbs Up Clayton.
Keeper.
Post #557580 20th Aug 2016 11:08pm
If I'd have known..
The Aeros aren't bad at £22 for all three, less for just the front. Would you like a link to where I got mine from?
Best price I could find they were.
Post #557581 20th Aug 2016 11:27pm
L110CDL
No worries Steve, i always sit on the fence for a while Whistle Yes please Steve, not a bad price at all, just for the front 2 please as i haven't got a back wiper Rolling with laughter I also use Rain X on all off my glass, inside as well Thumbs Up Clayton.
Keeper.
Post #557584 20th Aug 2016 11:33pm
Post #557585 20th Aug 2016 11:35pm
Page 2 of 3 <123>
