Home > My Defender > My USW |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 |
6th Aug 2016 8:33pm |
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3149 |
2011 110 USW
1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
15th Aug 2016 9:13pm |
I don't think he likes em getting mucky Ray
15th Aug 2016 9:17pm |
You'll never get rid of the Salisbury silt ...
16th Aug 2016 9:27am |
Still got it in my ears from Foggies driving Steve Will wear my own snorkel next time!
16th Aug 2016 11:21am |
I'm still struggling to get whatever this crap is from the Billing off road course off. I guess I will have to keep at it. It seems to stick to the waxoyl underneath, and needs a good scrub to get it off the bodywork. 2011 110 USW
18th Aug 2016 6:23am |
Near impossible to get it out of all the nooks and crannies a real PITA job. I regularly spend a whole day on and off flushing, hoovering when dry with small long extensions, poking around with wires, jet washing etc etc to get it all out as it can rot through a box section in 5-8 years even if previously treated with Waxoyl.
It will all be in those oval cut outs in the rear wheel arches, in the tub supports, rear crossmember off course and on top of it from the inside very tricky to get all that out, take out the plugs from underneath near the end of the rear seat box and try and get it out bottom of A & B post... The list goes on... Including the box section crossmembers high up under the main body, will never be able to get it all out from there... You cannot get it all off with jet washing, the majority has to be done by hand with cone brushes, wires, flushing and flushing and flushing. You have to get it all out as you don,t want to seal damp mud in when it comes time to re apply cavity wax... As yours is a keeper once cleaned and waxed I would use an old Series hack for playing in or borrow someone else's Defender that they don,t care about. 10 mins of playing in the mud can never be really undone. |
18th Aug 2016 7:57am |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5035 |
Drive it through a river and have done with it
You could wast your life cleaning out the inner parts of the chassis - never do it and it get written off 10 days later!! I do laugh though as the farm hacks i see, that would be luck to have a day clean, get abused for years and are fine. Whatever you do, eventually it will need to be repaired (this comes from someone who treated his from new and has treated his others from new and kept them going for 16yrs...with full off roading! Mike |
18th Aug 2016 3:46pm |
Got the truck back today, has been with Guy Salmon Stratford all week for (another) new rad panel. Can't complain though, paintwork looks good and they did a thorough wash and valet on the thing, plus put loads of that black polish stuff all over the tyres for some reason...plus I had a free coke. 2011 110 USW
26th Aug 2016 8:06pm |
Coke... Now that would strip clean the inside of your chassis
Good to see you have still got all your Series How is the One Ton doing these days? |
27th Aug 2016 7:36pm |
Right, looks like this has come back to bite me in the arse! I noticed only the other day that my door and bodywork are fouling and both are being worn away! Eventually there is going to be serious corrosion here. There is no slop in the door, so it looks like when it was put back together the door closing was not checked. I am really unsure how to proceed with this, I think the work was done via Grange Barnet, but I am not sure who to contact, I know the guy who was running things back then has since moved on. Any suggestions anyone, I can't leave it like this but the cost will be £££ to get this fixed, at the very least it needs a new capping. My current dealership I use locally have told me to go back to whoever did the work before... See wear on outer edge of door, quite hard to see but it is there. Click image to enlarge Wear/damage on capping. Click image to enlarge :( Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated 2011 110 USW 1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
2nd Sep 2016 3:53pm |
Doesn,t seem to be a huge problem if the door just needs re adjusting at the hinges?! Or as they do in the factory use a hammer handle to bend the door so it fits
2nd Sep 2016 4:26pm |
I imagine the adjustment will only be a matter of moments, I am more concerned about damage and corrosion to the bodywork and door. The paint has been worn off right down to bare metal. Both parts are steel... 2011 110 USW
2nd Sep 2016 4:33pm |
No problem just rub back, apply acid convertor, undercoat and touch up paint then laquer. LR will sell you the Keswick green touch up paint and Laquer. Kurust etc for the acid convert and undercoat, shouldn,t show too much It looks to have only taken off the surface paint a little bit...
2nd Sep 2016 4:36pm |
