Home > Technical > Nanocom Evolution, Problems,Hints and Tips. |
daviec1 Member Since: 30 Nov 2010 Location: Ayrshire Posts: 246 |
Good plan.
My tuppence: I had 3 licenses, numbers 1, 2 & 3 Stuck them into boxes 1, 2 & 7 (weird), and now get access to all 4 modules I need (engine, map, AS10 & WABCO) Learned today that programming a new key fob, do NOT wait for a horn or hazard flash as it tells you too, cos you'll be there all day, and probably just immob the vehicle & wipe your "good" fob Just hit the fob, hold it for a few secs, then start the car, switch it off & fob works perfect. Now if I can just figure out why the siren does not sound when I tell the nanocom to activate it - checked all the fuses etc....... 2001 TD5 110 DCPU in Bonatti Grey |
18th Jan 2011 4:38pm |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
If you like me have big fingers, get yourself a stylus. They work on the evolution and saves the screen getting greasy fingerprints all over it.
Click image to enlarge |
18th Jan 2011 4:40pm |
Bomber82 Member Since: 20 Oct 2009 Location: Alessandria - Italy Posts: 216 |
Regarding Puma version, there is the possibility to modify the speed limiter, I've tried many times but it seems don't work...
Does anybody confirms?? Matteo Defender 110 Td4 SE MY 09 |
19th Jan 2011 1:57pm |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 |
Tried that, seems to reset itself to 140, Kph I suspose. Put in 180 but next day it was back to 140. Shame.
Merlin |
19th Jan 2011 6:43pm |
I think that only works for vehicles which have Saudi Arabia set as the country of use, in the ECU when new. As far as I am aware SA is the only country setting which allows the removal and adjusting of the speed limiter with the nanocom, you can get the speed limiter removed if you get your ecu re-mapped, such as Pete's BAS remap |
19th Jan 2011 9:20pm |
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 587 |
Here is my contribution to the hints and tips.
I like to look after my stuff and thought that the Nanocom although sturdy could do with some extra protection on trips ( hopefully all it will do is rattle around in my cubby box ) I found a Peli case which fits perfectly, although not waterproof is crushproof. If I could only work out how to use it now apparently BBS are going to upload video tutorials which will be great. EDIT: the case came with a rubber insert which I removed, I have also stuck some high density foam strips around the nanocom to stop it rattling. The sticky foam bits on the lid do nothing and are coming off. Click image to enlarge Click image to enlarge |
22nd Jan 2011 10:35pm |
Hi, I like your peli case 1060, where did you buy this and how much was it? Merlin
29th Jan 2011 11:47am |
Gunner Member Since: 31 Dec 2010 Location: Oxfordshire Posts: 6 |
Obviously a complete klutz as I'm falling at the first hurdle of trying to enter the unlock codes into my new Evolution.
After registering the unit on the Nanocom website I now have codes for License numbers 1,2 and 3 After reading the instructions as I understand it License 1 should be entered in Unlock Box 1, License 2 in Unlock Box 2 and License 3 in Unlock Box 3. The problem is that there are already codes in these 3 boxes and I'm unable to enter or overwrite my new codes. The cursor is a the front of the string of existing numbers/letters and I'm only able to enter the first digit of my new code. There doesn't appear to be a way of either moving the cursor to the right and therefore being able to delete any of the existing digits or entering any other digits of my new license codes. Probably missing something so obvious but any advice would be appreciated. |
29th Jan 2011 1:06pm |
Gunner, Hello and welcome to the forum The touch screen allows you to place the cursor to the right allowing you to delete the code already in the box so you can enter the new one. You can also use the arrow keys to move the cursor to the right. You will also find it easier to input the details using the tip of a biro or a stylus as the keypads a bit small. HTH Brian. |
29th Jan 2011 1:49pm |
Thanks, the advice of a biro tip was a big help as it was my big fat fingers which were causing the problem.
Now the Nanocom is up and running it seems as if I have hours of fun ahead although after a quick look through it was good to see that there were no fault codes logged which would be a cause for concern. |
29th Jan 2011 2:32pm |
Hi Merlin, Off da bay http://shop.ebay.co.uk/?_from=R40&_trk...Categories Steve |
29th Jan 2011 7:04pm |
CFB Member Since: 13 Sep 2007 Location: Bradford, West Yorkshire Posts: 803 |
Had same issue with the screen cursor position, took me ages to fathom it out.
Only tip so far is a bit off topic for this forum but on a TD5 Disco 2, the air suspension transport mode setting is inverted, so to put in transport mode you save the setting as DISABLE and to get it back out save as ENABLE. This caused me major stress as I couldn't get it out of this mode until I got the info ref the inverted settings!! Andy |
29th Jan 2011 7:37pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5054 |
You got it fixed then! Mike |
29th Jan 2011 10:39pm |
Eventually, after numerous emails to Peter then Mattia at Nanocom Andy
30th Jan 2011 9:09am |
