Home > Technical > Nanocom Evolution, Problems,Hints and Tips.
Page 2 of 5 <12345>
mse
CFB wrote:
Eventually, after numerous emails to Peter then Mattia at Nanocom Thumbs Up
Good stuff either way! Mike
Post #55719 30th Jan 2011 10:39am
MK
Where do you intall the driver? Embarassed Puma 110" SW
Post #57023 5th Feb 2011 10:16pm
MK
anybody? Idea Puma 110" SW
Post #57336 7th Feb 2011 10:46am
CFB
I didn't have to install any drivers, just switched it on, got the codes from the website, entered them and it was away. Andy
Post #57350 7th Feb 2011 12:02pm
mse
Me to Mike
Post #57517 7th Feb 2011 7:58pm
Lorryman100
Could be wrong, but the driver is for the Nanocom desktop program for the nanocom 1 series. The preferred connection is by RS232 through COM-1 etc, but most modern laptops/desktops only have usb connections, hence the need for a usb driver to be used in conjunction with a RS232 to usb lead.
Post #57545 7th Feb 2011 8:40pm
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
Have been playing with my Nanocom today, Tried for ages to get the 'Nanocom Graphic viewer' to work but it wont recognise the files the unit saves Sad
So imported the data into excel and made my own charts, there are a few strange spikes but on the whole it all looks ok.
Top chart is throttle positions and battery voltage
Middle chart is injector readings
Lower chart is road speed blue/airflow red/manifold pressure green
Does anyone know if the Graphic Viewer is compatible with the Evolution?
Post #78994 4th Jul 2011 6:49pm
Lorryman100
I too have tried to get the CSV files loaded into GV but found the files corrupted and were not recognized by the GV program so assumed that the GV is only compatible with nanocom 1 and not the evo. I use data capture and use excel to show the highest values and to make graphs to show the recorded values but find the graphs show too much data and the info I'm after is lost in the clutter. As CSV (comma separated values/variables) files are easy to read in excel it is easy to separate them and compare the info you are after, ie Fuel rail pressure, injectors, rpm, engine coolant temp (cylinder head) and then make a graph to compare the info you are after over the period you are monitoring.
Some light reading: http://creativyst.com/Doc/Articles/CSV/CSV01.htm
Post #79913 12th Jul 2011 9:45am
Macpaul
United Kingdom 2013 Defender 110 Puma 2.2 USW Loire Blue
Resurrection!
Can someone (and it might be you Lorryman!) explain to a non-IT literate bloke how to create graphs from the comma separated values files collected from a Nanocom Evo 2 on an SD card.
I can open the .csv file in Excel, which produces what you might expect, comma separated lines of figures for each of the many parameters at a given moment in time, but I'm Censored if I can turn them into something readable. Tried Googling etc to no avail.
Thanks.
Simon. 2003 Td5 110 Hardtop
Now a 2013 110 USW too.
Post #323677 14th Apr 2014 3:47pm
kmac
Depending on the version of Excel used, a CSV file usualy opens with Excel automatically putting the values into separate cells depending on the commas
If you find that the data is all in one cell or column with comms still there, do this.
Select the data
The choose the data menu, then select "text to columns" then wehn asked for separator select "commas"
Once you have the data in separate cells, just highlight and select "chart"
Post #323727 14th Apr 2014 7:24pm
Macpaul
Thank you. I'm trying this on Excel for Mac Evil or Very Mad
The data for each given sample (the whole line of output covering all readings at a moment in time) is in one cell, hence the confusion.
I'll try what you suggest and have another go. And probably find myself a PC.
Thanks again.
Post #323742 14th Apr 2014 8:05pm
kmac
no need for a PC, should work fine on a mac (i have a mac as well)
Post #323868 15th Apr 2014 12:38pm
110 John
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Orkney Grey
Got a problem with mine Evo 2 did the latest BBS V1.23 upgrade but my functions are locked the codes are entered correctly and saved have tried reinstalling the upgrade numerous times re entered the codes but still the functions are locked any ideas
Post #324539 18th Apr 2014 5:25pm
willyj
United Kingdom 2011 Defender 110 Puma 2.4 USW Stornoway Grey
Just purchased a nanocom evo second hand. How do I re-register it to myself(the forum etc.)?
also, I need to purchase defender td5 and tdci, do I need the can bus lead for the tdci?
any help would be appreciated Thumbs Up
Cheers Wil
Post #324592 18th Apr 2014 9:00pm
110 John
Email them ask the question since the product will all ready be registered they can change it they are on holiday till monday 28th
Post #324621 19th Apr 2014 2:50am
Page 2 of 5 <12345>
