Home > My Defender > What Did You Do In Your Defender Today |
Hairysteve Member Since: 15 Jun 2015 Location: Surrey Posts: 692 |
West Wittering beach
14th Aug 2016 11:30am |
Click image to enlarge |
14th Aug 2016 11:32am |
Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674 |
Thought I'd finally clean out the back and even sweep the floor in doing so I found a can of cavity wax and as its been dry I thought it would be rude not to top up the bulkhead and doors, I proceed to take out the top hinge bolts and squirt until droplets appear on the floor, brilliant I thought now I can do the doors..... Onto the rear door as it was open; insert extension tube, squeeze and off it pops now lost to the internal cavity of the door frame never to be seen again..... B ! Oh well at least the bulkhead got a coating. Now time for a well earned ice cream 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
14th Aug 2016 2:02pm |
Washed, clay bar, and rewaxed so it looks nice and sparkley again Ray
14th Aug 2016 4:12pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20299 |
^^^^ This time of year dust is the issue not mud and wet.
14th Aug 2016 5:09pm |
Not up north at the top of the Pennines it isn't Ray
14th Aug 2016 7:10pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10733 |
After i finished work yesterday a bit earlier than i thought, so i set about replacing the Cigarette lighter socket as it had stopped working (original one) with a blue sea double usb unit, all went well, just had to file the hole a bit bigger to take the unit, that done i set about the wiring as i didnt want to use the original wires as i wanted to use it without the engine on, that sorted with a on/off switch in line and finished that this morning
Click image to enlarge Click image to enlarge With that finished i still a bit of time before our guest was coming, i set about fitting these, all was ok, had to do a bit trimming here and there, very pleased with them and will see how they do in the wet Click image to enlarge Click image to enlarge I used a clear silicon to fill the join as that is what you can see in the pics to make sure that no water comes through 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
14th Aug 2016 8:41pm |
They work very well at stopping the spray up the sides I've had mine on for about a year Ray
14th Aug 2016 10:05pm |
Keeper. Clayton. |
14th Aug 2016 10:17pm |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5804 |
Went on a recce of new routes for Mrs Grenadier and I. Nice day out....Mont Blanc, top right of the first pic
Click image to enlarge Click image to enlarge Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
16th Aug 2016 9:22am |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 |
Took her in for a Mot.
Should be fine. Should Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
17th Aug 2016 12:06pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10379 |
@Gren...Y-Foil...retro!!!
17th Aug 2016 2:46pm |
WeiB.beer Member Since: 13 Apr 2016 Location: Hertfordshire Posts: 58 |
Not quite 'today' but last weekend the defender took my friends and I up into the mountains in Ras Al Khaimah (United Arab Emirates), from where we hiked for 10hours.
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge 2015 110 Defender Heritage Utility Station Wagon 2014 B8 Audi RS4 2003 Audi A2 1.4 Tdi |
17th Aug 2016 3:21pm |
Bought 18x paving slabs weighing about 16kg each home.
Not the biggest but more than enough on a warm day to load and unload! |
17th Aug 2016 3:30pm |
