![]() | Home > Puma (Tdci) > Stainless exhaust decat worth the mod? |
1978 Member Since: 04 Aug 2015 Location: Lancashire Posts: 519 ![]() ![]() ![]() |
I have the TD5 version of the flatdog stainless steel decat pipe and it's made a positive difference to both noise and responsiveness. Much less than �500 if a decat is all your after:
http://www.flatdoguk.com/de-cat---puma-tdci~266 Hope that helps. |
An answer I posted from an intercooler thread of yours......but at �500 I would say definitely not for that price!
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1983 ![]() ![]() ![]() |
Thanks, the �500 is for a full exhaust, which is the quandary I have,
Option 1 fit decat pipe or option 2 full exhaust? 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
Option 3..... contact James Beard the 'horse dentist' (do a search on the forum using 'horse dentist') of Griffin. There are numerous members that have one of his stainless systems fitted (myself included) and it cost nowhere near the �500 you mention and has a no quibble lifetime guarantee. I will 'pm' you his mobile phone number and you can discuss directly with him your requirements! (If the number is still good?)
http://www.griffinperformance.co.uk/ If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Cheers K9
did you have the dummy cat fitted? and have you noticed the difference? 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
I designed and got my own 'cat' made up in stainless and welded it onto the decat pipe in the same position the TD5 cats are sat. No mither since.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
v8steve Member Since: 18 Apr 2011 Location: dumfries scotland Posts: 195 ![]() ![]() ![]() |
got a full griffin system for my 110 delivered today. with a dummy cat and straight through middle box. can't wait to get it fitted on saturday.
![]() s3 swb soft top |
let me know how you get on steve! have you got a 2.4? will it make that whoosh sound when you change gear? 2023 Defender L663 V8
Dieselhead Member Since: 21 Oct 2012 Location: Pulborough. West Sussex Posts: 552 ![]() |
I have that woosh when you change gear
Just got a decat brit part (yes I know but what can go wrong with that) No centre box Sounds like Darth Vada up the pipe. Want to find a tunnel ![]() Yes it does help the MPG ![]() 2008 XS 110 2.4 Utility. Tonga Green 1953 Series 1 for restoration 1983 Mini Mayfair 2004 VW T5 Camper 2008 Diahatsu Sirion. Thats hers Classic Bolens Garden Tractors |
will do + yes 2.4
Cold_n_Wet Member Since: 15 Oct 2012 Location: Bergen Posts: 247 ![]() ![]() |
I had a decat on the 2,4, with no middle box either, I didnt like the sound of the turbo over run so im building back to standard.
The Decat may go on again with the middle and rear boxes at a later stage "Rafiki" 2007 110 STW - Rolling rebuild. |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3791 ![]() ![]() ![]() |
Not saying a "De-cat" exhaust won't look & sound nice,...will probably make you feel good too, but I would suggest that any actual performance gains will be minimal, if any,...the "bum dyno" sometimes does not tell the true story.
Not familiar with your "laws", but don't you guys have a yearly "M.O.T." or something like that to pass yearly? Pickles. |
Yes we do have MOTs Pickles and there is loads of information readily available about decat and MOT if you are that interested and care to look. It is a well proven and documented fact that the turbo spools up quicker once the cat has been removed. As a result there are the associated increased gains to be had at an earlier stage.
May I ask what are you basing your 'suggestion' on please? Pete or Gary could undoubtedly expand further? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Explain?...Not a problem, I don't need to, I'm simply giving my opinion, on this "exhaust only" mod.
HOWEVER, if the guy proposing to do this mod, is agreeable to a "before & after" run on the rollers, providing power & torque readings, WITH NO OTHER MODS, he may find that I'm not too far off the mark. That is the only true way to establish the FACTS. Dyno reading graphs showing power & torque throughout the rpm range,..and like I said, for the car to be in IDENTICAL tune/condition, before & after. That is the only true way to establish any power gains. What happens with the M.O.T., if the decat was found to be removed? Pickles. |
