![]() | Home > Wheels & Tyres > Tracking |
Pinky Member Since: 09 Jun 2016 Location: England Posts: 210 ![]() ![]() ![]() |
I may be totally wrong here but the Tracking and radius arms are concerned with different things.
Tracking toe in or toe out by +or - is just that, moving the wheels inward or outward from dead ahead. Not sure what it should be on a permanent 4x4, rear wheel drive is I think generally toe out and front wheel drive toe in. (could be the other way!) 3 degree radius arms as I understand it is more to do with twisting the axle back into position if you have given it a lift in excess of 2" with longer springs, correcting the castor angle. Happy to be corrected but that is my basic understanding! |
SingletrackFred Member Since: 23 Mar 2015 Location: Reading Posts: 66 ![]() ![]() ![]() |
Thanks Pinky, it's my lack of mechanical understanding!
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4796 ![]() ![]() ![]() |
Toe in gives straight line stability as the wheels are turning into each other.
Toe out gives sharper turn in with the compromise of twitchy handling in a straight line. Neutral toe to very slight toe in is best for a defender, especially considering the lift on yours ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
I have my defender setup completely road biased with lowering springs etc. Mine is 0° toe and handles / turns in lovely
