Home > Wheels & Tyres > Tracking
SingletrackFred
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Corris Grey
Tracking
Hi All
I have read that setting your tracking positive i.e. +1 or +2 gives better road manners that a negative toe. Has anyone tried this and does it have an effect? Alternatively adding HD radius arms to give a +3?
Thanks
SingletrackFred
Post #553348 3rd Aug 2016 10:12am
Pinky
England 2011 Defender 110 Puma 2.4 DCPU Baltic Blue
I may be totally wrong here but the Tracking and radius arms are concerned with different things.
Tracking toe in or toe out by +or - is just that, moving the wheels inward or outward from dead ahead. Not sure what it should be on a permanent 4x4, rear wheel drive is I think generally toe out and front wheel drive toe in. (could be the other way!)
3 degree radius arms as I understand it is more to do with twisting the axle back into position if you have given it a lift in excess of 2" with longer springs, correcting the castor angle.
Happy to be corrected but that is my basic understanding!
Post #553441 3rd Aug 2016 5:10pm
SingletrackFred
Thanks Pinky, it's my lack of mechanical understanding!
Post #553518 3rd Aug 2016 9:41pm
grafty99
Toe in gives straight line stability as the wheels are turning into each other.
Toe out gives sharper turn in with the compromise of twitchy handling in a straight line.
Neutral toe to very slight toe in is best for a defender, especially considering the lift on yours Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #553752 4th Aug 2016 8:03pm
grafty99
I have my defender setup completely road biased with lowering springs etc. Mine is 0° toe and handles / turns in lovely Mr. Green 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #553754 4th Aug 2016 8:05pm
