Home > Technical > oh no wipers agin
ppad
United Kingdom 2005 Defender 90 Td5 HT Caledonian Blue
oh no wipers agin
Grrr Evil or Very Mad on the 2005 90 ... after 3-4 dry weeks I flick the switch , they move 6" up the screen after a bit of a crack, then stop. Nothing. At all. Changed / checked the fuse in the centre fuse box. Nothing. Screen wash yes. Wipe of any sort, no. So, options? Don't say the relay again the other side of the dash? Might it just be the switch? Why will the wipers not work? Thanks... Sold the much modified 110 2.8, in Oz
Brought the 90 home from Switzerland ...
Post #552837 1st Aug 2016 1:33pm
Rickydodah
First thoughts would be that one of the wheel boxes has seized, can you move the blades at all, even a small amount? Thumbs Up I started with nothing and still have most of it left!
Post #552938 1st Aug 2016 7:31pm
ppad
Summer time ... it's p...ing down out there. OK thanks, they were locked solid. So graunch graunch brute force to move them a cm, and they unlock and appear to move Thumbs Up
I'll check again in the morning. Maintenance needed? Sold the much modified 110 2.8, in Oz
Post #552942 1st Aug 2016 8:04pm
Hufflepuff
I had exactly the same thing last month on a 2005 td5. Get out of the car and manually move them - you might find they spring back into life again! (be gentle with them though, just 'help' them through a cycle)
Post #553083 2nd Aug 2016 12:14pm
Hairysteve
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Barolo Black
More info here that helped me fix my wiper issues (just in case) - http://www.defender2.net/forum/topic42567.html
Post #553089 2nd Aug 2016 12:34pm
In that case it is almost certainly a worn wheelbox. Once worn it is possible for them to lock until jiggled.
Post #553105 2nd Aug 2016 1:35pm
Another thing I notice after periods of no use in dry weather is they can stick to the glass.
I tend to free them after a while just to stop that happening.
Happens on my rear the most which is where the sun comes in, so it's drier.
Post #553120 2nd Aug 2016 2:23pm
ppad
Thanks to the chaps that know for their accurate suggestions. Bow down
So, a list of jobs to make and parts to collect (some light switches for front and back, rev guage .. and the full wiper bits) for when the whole flamin dash comes off ... on a couple of sunny days to take my time. Sold the much modified 110 2.8, in Oz
Post #553495 3rd Aug 2016 7:31pm
Waldo
I had the same problem, I removed the wheel boxes.
Clamped the box end in a vice
Clamped the thread in a drill
Turned it at low speed while applying liberal WD40 to basically free up and get any crap out and then gradually increased speed over time.
Once they spin very easily by hand I replaced them but made sure it was the fresh unused portion of the pinion that would be used (they only use approx 45% of the wheel max so the rest should be unworn).
Also applied lots of grease to them on replacement.
Total time for job maybe 2-3 hours.
Will Defender 90 XS TD5 (03 Reg)
Post #553684 4th Aug 2016 12:37pm
