Home > Puma (Tdci) > puma gearbox - thoughts |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6308 |
as mentioned elsewhere I should be replacing my gearbox in the not too distant......
question being should I retain the old box for a rebuild and potential refit in years to come or sell it? If I sell any thoughts on where best to sell it and at what sort of cost. the box will have completed circa 50k miles as it was a replacement under warranty when my def was approx. 2 years old. thoughts / suggestions much appreciated. |
30th Jul 2016 7:42pm |
Erm...
And some more .....i'm prepared to take a chance Perhaps I'll keep it just in case tho. |
30th Jul 2016 8:59pm |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3786 |
What's wrong with the "old" one, how "old" is it, & how many miles has it done?
Pickles. |
30th Jul 2016 9:03pm |
G'day Pickles
Possibly nothing but through a process of elimination I'm determined to sort my rather annoying intermittent clatter. It's my second box and has done approx 50k miles. I suspect as a minimum either slave cylinder or restricter valve are pants and the box has to come out anyway so while at it I might as well change the box and check out the clutch and adapter shaft too |
30th Jul 2016 9:10pm |
Morepower Member Since: 08 Jan 2013 Location: Fife, Scotland Posts: 630 |
If it changes gear, without any noises (grauging) between gears. Then I would suggest the gearbox is ok... Obviously check/change the oil whilst it's out.. The Clatter is more than likely to be the clutch.. removal of the gearbox should confirm this...
The TDCi gearboxes should be good for 250K plus if looked after.. It's just all the bit LR bolt on/in/around them that are usually suspect.. Clutch, Transfer box, Output shaft...ETC Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
31st Jul 2016 8:07am |
