![]() | Home > For Sale & Wanted > [Wanted] 300tdi engine good runner |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
Sorry to hear that
![]() Any idea on the cause? I cant help with the engine but at least 300Tdi' discos are fairly common. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter ![]() |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 ![]() ![]() |
I might have one will have a dig tomorrow
Interlet Member Since: 10 Oct 2011 Location: Norwich Posts: 461 ![]() ![]() ![]() |
Cheers Slim.
Shaggy, it's a rare occurrence, but after doing quite a bit of research, I've concluded that what happened was the cam bearings became slightly misaligned, restricting oil flow, resulting in a substantial drop in oil pressure, which I noticed, but not enough of a drop for the oil warning light to come on. The lack of oil flow resulted in the confirmed destruction of at least the big end bearings, but likely most of the rest of the engine bearings - essentially making it a write off. The research I did suggests this is heard of amoung all related engines - 200 and predecessors up to the 2.5 N/A. It just doesn't happen very often. 1998 110 300Tdi White Hard Top |
Rosso_NI Member Since: 09 May 2014 Location: NI Posts: 275 ![]() ![]() ![]() |
Interlet a mate of mine has just bought a 300tdi Range Rover Classic which he is breaking if any good to you but would need shipping etc. as based in NI
Let me know will find out more detail for you. 1993 Defender 110 Ex Military soft top, with a long wishlist already |
