Home > Maintenance & Modifications > Why weren't stainless caliper pistons standard?
agentmulder
Kuwait
Look at this:
The nickel (?) plating is even chipping off the internal side! (unless I dropped it since removal, but I don't recall doing so).
Are they meant to be a consumable?
And if so, why say to not split the calipers, but then offer internal seal 17H8764L (#14) as a spare:
la la la
Whistle
I cant wait to feel what a defender with pistons working on both sides of each caliper actually drives like. Shocked Solved the bowel problem, working on the consonants...
Post #551255 26th Jul 2016 5:37am
williamthedog
Probably boils down to one thing.....cost Neutral
Post #551268 26th Jul 2016 7:42am
ickle
You don't need to split the calipers to change the pistons, Zeus make stainless pistons so hopefully once done it should be set for many years- and yes it makes a big difference to straight line stopping!!
Keith
Post #551272 26th Jul 2016 7:51am
agentmulder
Kuwait
Changing everything because corrosion would have presumably damaged the seals.
The only way to get the seized one out was to split...
Sad Solved the bowel problem, working on the consonants...
Post #551275 26th Jul 2016 7:54am
Thon
I think the quality of the plating has gone down significantly recently. I just had all of my pistons and seals changed on my 2007 110. I used Zeus stainless steel pistons and genuine seals and don't think the cost was any greater all genuine.
They don't seem to advertise them on their website any more but if you call they will sort you out out.
Post #551301 26th Jul 2016 9:26am
miker
Mine were so bad I elected to chuck a set of new AP calipers at it. Any ideas on what I can do to protect/lubricate the standard pistons to make them last?
Post #551309 26th Jul 2016 10:28am
Martin
Site Admin
Quality of coatings has gone down because they are now using environmentally friendly processes. Chrome plating and similar is horrific for the environment and those working around it Shocked  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #551310 26th Jul 2016 10:30am
agentmulder
Kuwait
All the things I can think of off the bat would likely be really bad for the pads Neutral Solved the bowel problem, working on the consonants...
Post #551313 26th Jul 2016 10:36am
