Home > Maintenance & Modifications > Why weren't stainless caliper pistons standard? |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
Probably boils down to one thing.....cost
26th Jul 2016 7:42am |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1777 |
You don't need to split the calipers to change the pistons, Zeus make stainless pistons so hopefully once done it should be set for many years- and yes it makes a big difference to straight line stopping!!
Keith |
26th Jul 2016 7:51am |
Changing everything because corrosion would have presumably damaged the seals.
The only way to get the seized one out was to split... Solved the bowel problem, working on the consonants... |
26th Jul 2016 7:54am |
Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696 |
I think the quality of the plating has gone down significantly recently. I just had all of my pistons and seals changed on my 2007 110. I used Zeus stainless steel pistons and genuine seals and don't think the cost was any greater all genuine.
They don't seem to advertise them on their website any more but if you call they will sort you out out. |
26th Jul 2016 9:26am |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1763 |
Mine were so bad I elected to chuck a set of new AP calipers at it. Any ideas on what I can do to protect/lubricate the standard pistons to make them last?
26th Jul 2016 10:28am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
Quality of coatings has gone down because they are now using environmentally friendly processes. Chrome plating and similar is horrific for the environment and those working around it 1988 90 Td5 NAS soft top
2015 D90 XS SW |
26th Jul 2016 10:30am |
All the things I can think of off the bat would likely be really bad for the pads Solved the bowel problem, working on the consonants...
26th Jul 2016 10:36am |
