Home > Maintenance & Modifications > Lowered Springs Issue - HELP!!
mcmen
Hi all,
I fitted lowering springs from Urban Truck late last year. It only occurred to me the other day after washing the car that the rear springs are un-even..? Land Rover say the springs are the issue but Urban are not agreeing this theory.
What other springs would you recommend that will lower by 2' inches at both front and rear?
Pictures would be appreciated
Thank you
Tom
Post #549945 20th Jul 2016 10:37am
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
Not sure I understand what the problem is, have you measured the gap between the axle and the chassis on both sides ?
Have you tried it without the shock absorbers attached ?
It's normal for the driver's side springs to be taller/stiffer than the passenger side, there's no point in looking for a different supplier if it's not the springs that are the problem.
If you know the sprung weight at each corner you can probably lower it by using standard Land Rover springs, there is a huge range available and they're often cheaper than after market offerings. http://www.yorkshireoffroadclub.net/
Post #549954 20th Jul 2016 11:23am
LiftedDisco
Speak to these folks - they know lots about springs...
www.coilsprings.co.uk
If nothing else, their website is reasonably amusing...
Post #550066 20th Jul 2016 7:00pm
MartinK
LiftedDisco - thanks, looks a great company - I have emailed them about my own needs. Thanks for posting Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #550144 21st Jul 2016 7:23am
1978
United Kingdom 2003 Defender 90 Td5 HT Belize Green
They certainly sound like they have a sense of humour at that place!!
Quote:
In 2015 you cruising Hot Hatch needs serious Slamming, but correct rates to cope with heavy Sub-Woofers and speed bumps - We are the answer.
25 / 30 / 40 / 50 / 60 / mm or LOWER - WE CAN HELP YOU - NO PROBLEM
* If your Beemer 3 - Series has 500 kg of ice in the back and you still want a 60mm chop - We is the Main Man!
* If your Clio rolls like a jelly when your doing donuts in Tesco’s car park - steal a mobile and phone us first
New lowering service
So you lashed out hard earned cash on a fancy box of (imported) lowering springs from one of the usual suspects. You spent all Saturday fitting the brightly painted (imported) items, lowering your pride and joy onto its tyres only to find ....... It's not gone down!!!!
You curse and swear and bounce the corners of the car. 15mm, maybe 20mm. Nothing like the 35/40mm promised on the box. Ringing the man who took your money, only to get some drongo--"sorry mate, give it a few months till they settle".
Relax, don't reach for the Glock- Help is near. We at Powercoil know how important that wheelarch filled look is to you. For a small fee we will modify your springs down to the ride height you want. No cutting, burning or chopping. Just a correctly engineered approach to ride height reduction.
Maybe next time you will buy "Made in Sheffield" British!!!
Post #550152 21st Jul 2016 8:00am
MartinK
Wow- been thinking about 5cm lower springs, 20% softer for ages... Rear only to take away that "jacked-up rear end" look. Just emailed coilsprings at 0822 today, Neil replied 0847. Keenly priced quote. Order placed Smile
Thanks for the tip. 4 weeks delivery time. Pics to follow Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #550155 21st Jul 2016 8:07am
Can't wait for that Martin!!
Post #550202 21st Jul 2016 11:36am
MartinK
Got a call a couple of days ago from coilsprings...they are ready Smile
Collecting tomorrow...should install next week
Write-up to follow Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #560157 31st Aug 2016 7:06am
Iggle piggle
United Kingdom 1989 Defender 90 V8 Petrol ST Alpine White
* Want to radically lower your Vitara down to crumpet pulling level? - sorry we’re good, but not that good.
Rolling with laughter Rolling with laughter Rolling with laughter
Post #560184 31st Aug 2016 9:33am
MartinK
Hopefully they (coilsprings) will be able to add:
"Allows you to run recommended Tyre Pressures (rather than 30psi) in your Defender rear tyres and still keep your fillings intact" Wink Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #560188 31st Aug 2016 9:48am
MartinK
Collected my new springs from coilsprings today
They're made on the premises in Sheffield.
Took a wee piccie whilst I was in there:@
Will fit next weekend and update Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #560729 2nd Sep 2016 8:43am
Capt_Steve
England 2014 Defender 110 Puma 2.2 XS CSW Corris Grey
Hi Martin,
How did you get on with your new springs, did they work out as you hoped?
Steve
Post #584308 11th Dec 2016 10:04pm
MartinK
Steve - yes thanks - very happy
see http://www.defender2.net/forum/topic49065.html?highlight=spring
I have not carried any big loads yet, or even towed my trailer...but yes I am happy...sound investment... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #584450 12th Dec 2016 1:54pm
Capt_Steve
Cheers mate Thumbs Up
Post #584454 12th Dec 2016 2:36pm
