Home > Puma (Tdci) > "Oil Can Sign"....Dash Waning Light? |
midlife Member Since: 15 Apr 2015 Location: Cork Posts: 122 |
It's not an oil pressure check light is it that lights on start then goes out normally. Think my does it but away from wagon at the moment
20th Jul 2016 9:24am |
Browny90 Member Since: 20 Jul 2015 Location: Derbyshire Posts: 183 |
if its red then yes, its your Oil pressure Light, will be on while the ignition is on, then when the pressure is seen at the sensor the light will go out, if it stays on for more than a few seconds, or if it comes on while driving then switch the engine off straight away to investigate.. My 1986 90 is currently on a full rebuild, with new chassis, Paint etc.. Very much a hybrid, TD5 Chassis, tub & bulkhead with a 200TDI and LT77 GB Painted in Stornoway Grey 2 years off the road, but getting close to completion now
20th Jul 2016 10:07am |
Mine goes out when the alternator light goes out, or if I don't wait for the glow plugs then it goes out when the engine management and glow plug lights go out.
It's so consistent I assume that's just how the logic works. |
20th Jul 2016 12:23pm |
