Home > Puma (Tdci) > Puma 2.4 injector codes label?
vaucluse
2007 Defender 110 Puma 2.4 SW Java Black
Did I read here somewhere that there's a label on the engine which lists the injector codes or am I imagining things?
Mark
Post #549681 19th Jul 2016 9:47am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Codes will be on the injectors themselves. 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #549692 19th Jul 2016 10:50am
bell-auto-services
My web site shows you where the codes are, hope it helps. http://bellautoservices.co.uk/help-faq/bas...ogramming/
Regards Pete
Post #549864 19th Jul 2016 9:40pm
vaucluse
Many thanks Pete.
I have the usual issue where my truck starts off from cold quietly and after 8 to 10 mins it starts to knock under light load (disappears when you gun the throttle) and after half an hour it quietens down - still perceptible but much quieter. Adding 2SO make it less noticeable.
It has me thinking whether it needs a pilot learn done perhaps? Anything else I should consider?
Mark
Post #549877 19th Jul 2016 10:39pm
