Home > Puma (Tdci) > Leak |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
I think first the windscreen seal or the one baulkhead to windsceen frame,and I thought yours was a water tight one. 2.4 90 XS
14th Dec 2008 10:37am |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5053 |
it is. is not the windscreen or the bulkhead to windscreen frame im 99.9% sure of that Mike |
14th Dec 2008 6:15pm |
Edd80Inch Member Since: 18 Oct 2008 Location: Devon Posts: 28 |
My 90 leaks in the same place as yours by the sound of it, I always thought it was through the heater recirculation vent, only now and again and enough to make a small puddle on the mat.
My dealer says he cant find a leak as the water out of a hose is a different viscosity to rain water,,,, Must be a relation of Stevie Wonder................ Edd 1999 90 TD5 County 1943 Ford GPW Jeep |
14th Dec 2008 8:48pm |
Thats the one - its not leaking as a leak i think the water is getting in the wing vent and down into the box through to the mat on heavy rain. Ive tried the hose, power wash and dealer - we all cant get it to leak on the window/door/seals/joints and having seen this straight out the middle of this vent - its not the standard leak, no damp on the bulkhead or dash - so...why; ill see when i change the vents. Mike |
14th Dec 2008 8:54pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6315 |
similar problem different side though?
noticed nothing for a couple of months (although perhaps we didn't have much rain -cant remember) and now a wet mat, dripping from what appears to be the bottom bracket for the dash board next to the retaining arm / strap for the door. |
14th Dec 2008 9:24pm |
Totally different sorry Mike |
14th Dec 2008 9:43pm |
Caterham, I would check windscreen and baulkhead seals as I thoght that might have been Mikes problem areas 2.4 90 XS
15th Dec 2008 8:27am |
Paul55 Member Since: 03 Feb 2009 Location: Somewhere in my head! Posts: 514 |
Has anyone had the problem of the leak resolved, just booked mine into the dealers this morning as I had a small swimming pool on the passengers footwell side this morning, after huge downpour in sunny Derby last night . It would be nice to take her in and have some info for them. Cogito ergo sum
15th Apr 2009 10:43am |
Windscreen seal,windscreen hinge bolts,door hinge bolts. 2.4 90 XS
15th Apr 2009 11:30am |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2110 |
Thanks grockle
Mine have the same problem from new Has been checked several times by the dealers but nothing has been solved Is now with the dealers for paintwork, so I will pass your info to them to be checked. Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
15th Apr 2009 2:08pm |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 |
Ours has finally been resolved after 5 or so visits to the dealers. It was taken to a 3rd party LR body shop three times and stripped and water tested. It seems to have done the trick although i won't be surprised to see a few drops on the mat in the winter. Bulkhead was the culprit apparently. As the main dealer told me when we were in full flow (excuse the pun) of arguments, "9/10 Defenders leak - farmers expect it" We were told that it was hard for them to test for leaks as rain water "is finer than tap water" and therefore might not penetrate the gaps in the overnight water test. I must get that tattoo saying 'gullible' removed from my forehead. |
15th Apr 2009 2:26pm |
